Dean in Eureka, CA wrote:Are 1/2" thick x 5 on 4 1/4" wheel spacers easy to find???
Said they need to be one piece to get the clamping pressure on the wheel.
Dean in Eureka, CA wrote:Brick,
I know woodworking, I'm OK with metalwork and I know enough about electricity to keep from getting shocked most of the time, but I'm lacking when it comes to the auto mechanics part of it... Have to ask many questions.
Was just pointing out what someone, I'd say... "Knows their stuff", said.
I too, had the thought... "Hey, this isn't a front end of a car with an engine setting on top of it."
Which leads me to my next question about wheels and tires...
OK, on a trailer... Is it better to have toe out or toe in?
madjack wrote:Dean, haven't you ever watched the cutaway car demos on Sunday...Brick is correct, it is basically a turning/steering thing on the front offa car...most trailers have some toein becuase the axle is bowed in the middle...this is a weight bearing thing...as more weight is applied, the axle straightens out, eliminating the towin on the trailer wheels....
Podunkfla wrote:Said they need to be one piece to get the clamping pressure on the wheel.
Dean... Huh? I don't understand what he means? All the "clamping pressure" is at the lug bolts. The strength of the wheel center provides the rest of the rigidity. Being bolted against a flat surface, like a hub face, doesn't add all that much. So I have to disagree with him. I'm sure you can get lots of other opinions too. The only thing you really lose is the center hole of the wheel going over a hub. All the load is being transferred just to the lug bolts... Which is no big deal on a lightweight trailer. in my humble opinion. Of course, I wouldn't prolly do this on the front end of my car. Hey, where's Andrew when you need him?![]()
I have done this a couple times to get clearance, in the past. Never had a problem.
