Propane Generator
Anything electric, AC or DC
Propane Generator
Postby Elumia » Tue Mar 13, 2007 11:02 pm
I haven't seen anyone broach this subject, but it makes sense to me. If you're going thru the trouble of bringing a generator, I suspect that you might have a propane canister - or it would give reason for carrying a bigger one. I'm not a fan of transporting gasoline either. Has anyone considered a propane powered generator? The only one I can find seems spendy though.
http://www.generatorquotes.com/order/EF ... iS_Bi_Fuel
Elumia
Images: 15
Postby madjack » Tue Mar 13, 2007 11:17 pm
...spendy is an understatement $> $> $> $> ...I am not planning on a gennie unit but for that price I could get a 2600watt Kipor and a LOTTA gasoline and have something that would actually power a coffee maker instead of just making it mad...
madjack 8)
Postby asianflava » Tue Mar 13, 2007 11:21 pm
I'm not a fan of transporting gasoline in the TV or tear. Even when sealed up, you will smell it. When I was looking for a genset, I found something about a conversion kit for the Hondas, but I'm not shure if it was for the small generators.
According to the stats listed on that page, a 20lb grill tank will run that generator for 85hrs, a 1 pound can should run a little over 4 hours. 4 hours should be enough to chagre batteries.
asianflava
Postby Elumia » Tue Mar 13, 2007 11:47 pm
here's a link for conversion kits
http://www.propane-generators.com/a-c_kit_list.htm
looks like $150-$200
Mark
Elumia
Images: 15
Postby bledsoe3 » Wed Mar 14, 2007 12:44 am
$> :shock:
I'll just strap a gas can on the tongue of my tear.
bledsoe3
Images: 112
Return to Electrical Secrets
