Fantastic Fan Question
Anything electric, AC or DC
Postby Mary K » Wed Mar 14, 2007 11:18 am
:o WOW Guy's. Thanks for all the input!!!
I have already installed the spars and frame...I think its at 14.5"... :thinking: I better check it when I get home.
Thanks again!!!! :thumbsup: :thumbsup: :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby madjack » Wed Mar 14, 2007 11:23 am
MK, check that your framing is at least 1.25 or better so as to have enough "meat" for the mounting screws...3/4" will be "too much not enough"(cajun slang)...
madjack 8)
Postby Mary K » Wed Mar 14, 2007 12:09 pm
madjack wrote:MK, check that your framing is at least 1.25 or better so as to have enough "meat" for the mounting screws...3/4" will be "too much not enough"(cajun slang)...
madjack 8)
Oh, It is!! I doubled up the 1x2's!!! :thumbsup: :thumbsup:
Now, I just need to cut out headliner without a router. :scratchthinking:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby toypusher » Wed Mar 14, 2007 12:11 pm
MK,
Unless you have a very long bit for your router you will have to cut from the inside. Hope you have a good full-head cover and an even better dust mask or respirator!! :shock:
toypusher
Images: 324
Postby Mary K » Wed Mar 14, 2007 12:48 pm
toypusher wrote:MK,
That's the thing, I don't have a router. :D
I don't need no stinking router, I build teardrop with dull knife!!!! Image
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby rbeemer » Wed Mar 14, 2007 2:04 pm
You can drill 1 hole in each corner and use a jig saw or a hand saw to cut the hole
Rick
If ducks had scales, would fish quack?
rbeemer
Postby bobhenry » Wed Mar 14, 2007 2:12 pm
MK
Take your drill and a small drill bit. drill hole from the outside thru the headliner tight in each corner.
Go inside and connect the holes with a straight edge and cut carefully on the lines with a circular saw or your jig saw. You can plunge cut the circular saw but be very slow and get a good grip it can take off on ya. The jig saw is a little slower but safer. If you stay just inside the lines you can use a rasp or sander to touch up the edge.
Postby bobhenry » Wed Mar 14, 2007 2:14 pm
OOPS
I type too slow Rick beat me ! :x
Postby Mary K » Wed Mar 14, 2007 2:17 pm
rbeemer wrote:You can drill 1 hole in each corner and use a jig saw or a hand saw to cut the hole
Yup, Thats perdy much how how I been cutting big holes all along.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby toypusher » Wed Mar 14, 2007 2:31 pm
Mk
Be careful when doing this. If you use too course a tooth blade or push a little too hard you can get some unwanted tearout or separation from the roof spars. JMO! :)
toypusher
Images: 324
Postby Mary K » Wed Mar 14, 2007 2:48 pm
toypusher wrote:Be careful when doing this. If you use too course a tooth blade or push a little too hard you can get some unwanted tearout or separation from the roof spars. JMO! :)
That's good information. :thumbsup: Thanks. I'm thinking about using a hand saw to cut it out. I'll have more control and not have a power tool over my head :frightened:
Wish I had a roto-zip thingie. :roll:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby toypusher » Wed Mar 14, 2007 3:03 pm
Mary K wrote:................
Mk
You can usually get one like that at HF for around $20.00!
toypusher
Images: 324
Postby Miriam C. » Wed Mar 14, 2007 5:07 pm
Mk
MK I used a jig saw from the Bottom and it worked fine. Had lab type safety glasses on so didn't get dust in the eyes though.
:roll:
Postby tonyj » Wed Mar 14, 2007 5:48 pm
If you used 1/8" or 2 layers of 1/8", you can also score and cut it with a razor knife. But be very keerful doing that, too.
tony
tonyj
Images: 160
Postby Laredo » Wed Mar 14, 2007 10:35 pm
If you haven't started cutting yet, buy some wide blue masking tape.
Drill your holes, put TAPE where your lines will go, mark on top of the tape, and you can cut it with lots less risk of tearout.
Laredo
Return to Electrical Secrets
