Sink Hole Tool Question
Postby Classic Finn » Wed Mar 14, 2007 6:16 pm
Good Morning from the Arctic Sky Shop :D :D ... I was wondering if this is the correct tool for making the hole in the bottom of the Sink Bowl or Mini Sink that Madjack or Mary K used...or mentioned,
Im doing so much here right now at one time that these things are just sprouting up all over the place and un announced... when not even searching...for things :lol: :lol:
Just by accident I was looking for a faucet to install and I stumbled upon this.....here in Reindeer Land
Image its 35mm in diam..and cost here is 8 Euro which is about 9 -10 USD.
Ohhh Please say that is the correct tool.... :worship: :worship:
Classic Finn :thinking: :roll:
PS I found some real genuine North American Cedar here as well ....Im running across some different ideas on it too .. man that stuff smells great. and looks very nice..
What does cedar look like when varnished or waxed?
Classic Finn
Midnight Sun Voyager
Images: 146
Postby toypusher » Wed Mar 14, 2007 6:49 pm
That certainly appears to be the correct tool to cut a round hole in metal.
toypusher
Images: 324
Postby Chuck Craven » Wed Mar 14, 2007 7:03 pm
That is the tool!
Make the hole for the bolt two drill sizes bigger than is needed. The slug will bend and gum up to the threads making it hard to tighten the bolt. Put some light machine oil on the threads. Crank a way you should end up with a hole the size of the die. It will be a little sharp so you need to do file off the burs. Use your safety glasses! :SG
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby Classic Finn » Wed Mar 14, 2007 7:03 pm
toypusher wrote:That certainly appears to be the correct tool to cut a round hole in metal.
:thumbs up1: :thumbs up1: :wakka wakka: :woohoo: All Righta Then..
Thanks Kerry... I know what I,ll be doing when the sun rises .... :hammer: :coffee:
On Da Road Again.... Going Places Where Ive Never Been... :lol: :lol: Life is A Voyage... :D :D
Classic Finn :thumbsup: ;)
Classic Finn
Images: 146
Postby Classic Finn » Wed Mar 14, 2007 7:06 pm
Chuck Craven wrote:That is the tool!
Chuck
Thank You Chuck... Yup My safety glasses are on already... :D :D :lol:
I be a Happy Camper....I,ll get some photos up for you again within the next few days.... :thumbsup: :thumbsup: :pictures: :shake hands:
Classic Finn ;)
Classic Finn
Images: 146
Postby Micro469 » Wed Mar 14, 2007 8:35 pm
Heiki.. that is the proper tool... but..... Your drain will NOT sit flush. In order for your drain to sit flush you have to dimple the bottom first. The way to do that is to get a punch,( the tool you found) a little bigger than your drain...usually about 3". Turn the cutter upside down, and crank it until it goes in about an!/8 to !/4 inch. Then cut your hole the size of your drain tube in the centre. This will make your drain fit flush with the bottom of your sink.
I tried it with a 2" cutter and it works. I don't have a 3", they cost about 245$ here in Canada.....can't convince my Boss to buy one :cry:
I did post this in another thread... I think it was Mary's when she got her sink.....
http://www.tnttt.com/viewtopic.php?t=13999&postdays=0&postorder=asc&start=0
John
Micro469
Images: 382
Postby asianflava » Wed Mar 14, 2007 11:51 pm
Save yourself some time and use an impact wrench to tighten it down. After cutting 4 or 5 holes, those dies get hot.
asianflava
Postby Classic Finn » Thu Mar 15, 2007 4:47 pm
Micro469 wrote:Heiki.. that is the proper tool... but..... Your drain will NOT sit flush. In order for your drain to sit flush you have to dimple the bottom first. The way to do that is to get a punch,( the tool you found) a little bigger than your drain...usually about 3". Turn the cutter upside down, and crank it until it goes in about an!/8 to !/4 inch. Then cut your hole the size of your drain tube in the centre. This will make your drain fit flush with the bottom of your sink.
Thank You John
I havent had a chance to try it out yet but I,ll give your directions a try..
I,ll let you know how it turns out..
Classic Finn
Images: 146
