A case of Crs.Again.. Cutting Styro for Wiring
Postby Classic Finn » Fri Mar 16, 2007 5:29 pm
I cant remember nuttin this evenin or should I say mornin now.... Bad case of CRS .... :?
Has it been mentioned at all as to how to go about making a nice groove cut in styro insulation for the electrical wiring? Ok other than a knife..
Mine will be inside of flexible coil... (plastic) but Id like to make the cut out so it looks nicely done even though it wont be seen...
Here is what I mean.. the wiring is already inside of this premade..
But Im Finnicky by Nature... :lol: :lol: :lol: :D Cant help myself... :roll:
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby toypusher » Fri Mar 16, 2007 6:05 pm
You could use a router. But watch the flying stuff! :shock: :)
toypusher
Images: 324
Postby Classic Finn » Fri Mar 16, 2007 6:11 pm
toypusher wrote:You could use a router. But watch the flying stuff! :shock: :)
Gee Kerry ....Wont a router melt it real fast like? :oops: :oops: :shock:
Classic Finn :duh :SH :coffee: :lol: :lol:
Classic Finn
Images: 146
Postby toypusher » Fri Mar 16, 2007 6:17 pm
I wouldn't think so at the temps you seem to work in! :D If it starts to get plugge up at bit it certainly would. But a straight bit the size of your wiring conduit should stay pretty clean. I must admit that I have not tried to use a router for this purpose. Just an opinion. Try it on some scrape insulation.
toypusher
Images: 324
Postby Classic Finn » Fri Mar 16, 2007 6:35 pm
toypusher wrote:I wouldn't think so at the temps you seem to work in! :D If it starts to get plugge up at bit it certainly would. But a straight bit the size of your wiring conduit should stay pretty clean. I must admit that I have not tried to use a router for this purpose. Just an opinion. Try it on some scrape insulation.
:thinking: :thinking: :thinking: :thinking:
Classic Finn
Kerry I may just be crazy enough to try it.... :lol: :lol: Once :D
Classic Finn
Images: 146
Postby toypusher » Fri Mar 16, 2007 6:55 pm
Might I suggest a dust mask or even a respirator??
toypusher
Images: 324
Postby Miriam C. » Fri Mar 16, 2007 7:16 pm
Heikki,
Perhaps if you make a shallow pass you will be able to see if it melts. You need to wear good eye protection. The little beads that come off this stuff (on a saw at least) are hot. I have a melt in my eye glasses and I used safety glasses.
Postby Sam I am » Fri Mar 16, 2007 8:08 pm
You could melt a channel with a large soldering iron. Use a straightedge as a guide. If you want a curved channel, draw a curved line with a marker and follow it by hand. Go slowly to keep it smooth. I've done this in foam wing cores on R/C model planes for years.
Sam I am
Images: 106
Postby IndyTom » Fri Mar 16, 2007 8:46 pm
I can't seem to find anything tonight. I can remember that someone here did cut their channels with a router and it worked well, just very messy. But I also remember someone used some sort of wire in their "gun type" soldering iron that was much less messy. I just can't seem to find either one tonight :x :x
Never trust a skinny cook
IndyTom
Images: 42
Postby IndyTom » Fri Mar 16, 2007 8:55 pm
Heikki,
OK, I am not nuts. Here is a link where Cracker used a hot wire to cut the channels. http://www.tnttt.com/viewtopic.php?t=7618&highlight=insulation+grooves+gun
Sorry about the long URL, tinyURL just disappeared from my computer.
IndyTom
Images: 42
Postby Chuck Craven » Fri Mar 16, 2007 9:21 pm
If you have an old gun type of soldering iron with the copper two-conductor tip like Weller makes. You can take a piece of #14 copper house wire and make a U shape hot wire cutter that will go through the foam like greased goose s!*$. :R :lol: :twisted:
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby Keith B » Fri Mar 16, 2007 10:01 pm
I put my foam on the table saw w/ a dado blade..
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby Mike Angeles » Sat Mar 17, 2007 8:17 am
Soldering Iron
tact /takt/ –noun
1. a keen sense of what to say or do to avoid giving offense; including the ability to speak or act without offending.
2. a keen sense of what is appropriate, tasteful, or aesthetically pleasing; taste;
Mike Angeles
Images: 76
Postby Classic Finn » Sat Mar 17, 2007 8:46 am
Keith B wrote:I put my foam on the table saw w/ a dado blade..
Keith
Ok tell me what does a dado blade look like ? As the word is not familiar to me... :thinking: :thinking: Im sure we have them here ...Would you show a photo of this blade? Perdy Please..
Classic Finn ;)
Classic Finn
Images: 146
Postby Classic Finn » Sat Mar 17, 2007 8:48 am
Ok we have a soldering iron here good and hot... just looking for a good size tip for it...
Classic Finn :lol:
Classic Finn
Images: 146
