sandman wrote:Excellent question, Elmo. I am just about to bolt my floor to my trailer today or tomorrow and was wondering the same thing. I was thinking about 8-4 on each side. I wonder what would be the best size to use 1/2". 3/8"?? Sorry, didn't mean to hijack your post.
sandman wrote:Dude, I am not even at that stage yet since I had to start over..lol. I ended up having to recut a wall when I tripped in my shop and fell onto the wall right after I had attached it to the floor several weeks ago. I just finished painting my custom made 6x12 trailer this morning. I have been waiting for good painting weather for days. I started painting on Friday and just did little by little and finally finished it this morning. As soon as the paint hardens up, it's time for the walls once again.
Did you get a Parallax Power Center like I bought off Ebay?
tonyj wrote:I don't have the technical info to answer (Andrew will probably pipe in!), but I think it will not necessarily be the number, but the combination of the grade of bolt, size of bolt, number of bolts, and weight of the box on the frame.
The worry is not that the box will blow off (if it did, you're using waaay too small bolts, dude!), but the shear strength of the bolts should there be a "driving speed" to "zero speed" incident that would make the weight of the box want to leave the frame and visit the inside of your vehicle. The next variable would be whether or not the sides stay affixed to the floor assuming the floor to frame bolts held.
Since I don't have the technical info to come up with the correct grade and sizing, I erred on the overbuilt side (I hope!) and fastened my floor to frame with 12, 3/8 inch grade 8 bolts spaced equidistant around the perimeter of the frame. I applied roofing emulsion to the top of the frame before laying the floor on it, so I think I get some additional adhesion strength there as well.
Not to leave the proper engineering out, I wanted to make sure that if the box left the frame, more than likely whatever I had just run into had already killed me. Like the old "bug hitting the windshield joke," I didn't want the last thing going through my mind to be my trailer.
Denny Unfried wrote:An important decision is the type of bolt used. I used (six) 3/8" carriage bolts with fender washers through the 3/4" plywood. With such a large footprint on the wood there is little chance of the bolts pulling through. I then used two nuts locked together on the bottom side to secure.
Another good choice would be elevator bolts which have large heads.
Joseph wrote:I used a bunch of stainless steel wood screws.
Joseph
