caseydog wrote:Well, what if I force the air through the small vent with a vent fan? That should have a similar effect to a largervent, wouldn't it?
The way a Little Guy is made, the bottom vent idea wouldn't be practical.
I don't want a huge vent on my galley hatch, if I can help it.
leaving the galley open a bit, or all the way, is okay in some circumstances, but not in others.
I'm hoping a small vent with a fan will work. What do you think?
CD
Dooner wrote:Asianflava, I still want to get down to see yours. If you are getting it to work with the estimated 144 sq in area cut down to 31 sq in, you are lucky. The heat buidup is causing the condensation. And if you can get another drain in it to stop water from settling at the bottom, that might help too.
DaveandDebbie wrote:Hey Caseydoy
I didn't get a chance to show you my AC at BB camp out I never hooked it up didn't need it. But if you are interested I'll try to get some photos uploaded of the finished product. I went with the sit it on the ground method I guess I should have hooked it up for show.Sorry . I just could not see giving up that much space for a perminent mount in my Little Guy
Just let me know Dave
caseydog wrote:Man, I am still messing around with do-dads to try to get airflow through my galley for the AC. Just tried one tonight, and it got in the way of my door strut on one side. Dayum, nothing is ever easy.
CD
caseydog wrote:Not sure what the ooops was for, Brick, but the idea looks good. I already have vent holes in the side, so I'd have to do it a little different, or fill some holes.
I'll figure something out, eventually. Hopefully I wont hack up my TD too much in the process.
CD
