madjack wrote:Lynn, I don't recal what kinda trailer frame y'all used...dooya know the weight rating of the springs...some things to try...check air pressure...if above 50#s try letting some out OR you can try some of these...
http://www.shockwarehouse.com/site/mon_retrokit.cfm
...if your spring rating is around or above 2000# you may have to remove a leaf to get it within range of your trailer weight....
jplock wrote:Lynn,
The way madjack sugested to you is the way I did my trailer. I removed the small leaf from the 2000 lb axle. I have the shock kit and run the tire pressure at 28 lbs on 15 inch tires. The trailer weighs 1,000 lbs and tows real good. I have been thinking of trying the tire pressure at 25 lbs due to the light trailer.
Phil & Ningning wrote:I can't see it for certain, but it looks as if your spring shackle is horizontal. If so, that would be your problem, and re-engineering the suspension geometry is in order.
Maybe my eyes are messed up.
Lynn Coleman wrote:Phil & Ningning wrote:I can't see it for certain, but it looks as if your spring shackle is horizontal. If so, that would be your problem, and re-engineering the suspension geometry is in order.
Hi Phil,
If the item at the front and back of the spring that connects with the frame is the shackle, than yes it is horizontal.
Is this difficult to change to a vertical position?
Can you tell I'm not a mechanic?
Lynn
Phil & Ningning wrote:Front and back?
If you are not sure, you should take it to a qualified trailer builder to sort it out for you.
Good luck!
