Phil & Ningning wrote:The front looks okay. I think if you move the rear mount aft it should take care of your problem.
Tire pressures are important, and you may want to consider shocks at some point, but as Madjack said, don't tow it again until the shackle mount is repaired.
Lynn Coleman wrote:Oh and do I need bushings? And if so, where do I put them. Correction, where does hubby or the original maker of the trailer put them. I'm definitely considering having him fix it at no charge to me.
Lynn Coleman wrote:Phil & Ningning wrote:The front looks okay. I think if you move the rear mount aft it should take care of your problem.
MadJack, Gage, Kevin A, Rich and Phil, Thanks so much for your input.
Okay, if I understand this correctly. We simply jack up the trailer, unbolt the bracket (or whatever it is called) that mounts the shackle, slide it backwards until the shackle is verticle. Then drill a new hole for the bolt and rebolt it. Is that correct?
Lynn
Phil & Ningning wrote:That's about it, Lynn.
Rich noticed that the spring mounting plates appear to be secured by just a single bolt. I thought they looked welded. Welding is okay, multiple bolts are okay, but certainly one at each location is insufficient. The bushings should already be in there.
Might I suggest that if your builder does the repairs for you, that you get a professional to check the work.
Cheers
Phil
madjack wrote:..that'll work...bushings would be on the bolt as it goes thru the spring eye....if the mounts are only on with one bolt I would definitely add another...either a #5 or #8 bolt...I would definitely say something to the guy who built the trailer but I would be leery of letting touch anything.....
madjack wrote:Lynn...one last thing...the last thing you need to do is add a leaf to the spring pack...you have plenty of spring already...it is the geometry that is wrong...after you move the shackle to the proper position, you can try lowering air pressure or adding shocks...adding shocks is always a good thing, which is why I like the torsion axles so much...spring/shock all in one unit.....
madjack wrote:Lynn...one last thing...the last thing you need to do is add a leaf to the spring pack...you have plenty of spring already...it is the geometry that is wrong...after you move the shackle to the proper position...if needed...you can try lowering air pressure or adding shocks...adding shocks is always a good thing, which is why I like the torsion axles so much...spring/shock all in one unit.....
Lynn Coleman wrote:Oh, and fyi we have 15" tires, leaf springs and the trailer weights 1300lbs.
angib wrote:Lynn Coleman wrote:Oh, and fyi we have 15" tires, leaf springs and the trailer weights 1300lbs.
You can look up the appropriate tyre pressure for trailer tyres from this Goodyear load-inflation table:
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
So if you have 205/75R15 trailer tyres (of any load range), just 15psi will give you 1810lbs (2 tyres @ 905lbs) capacity, so that's plenty more than you need. Elsewhere I've seen a recommendation for 10% higher pressures at higher speeds, so you might want to make that 17 psi for 75mph!
Andrew
Oops, sorry, didn't mean to interrupt the bad spring hanger discussion, which needs to get fixed before anything else.
critter wrote:Hey All,
Here is my 2 cents worth.If i paid this guy good money to build the trl he would fix it or id get my money back.If he dont known how to fix it what is he doing building trls.Ray Charles can see that aint right.TAKE IT BACK!Its just an oversite on his part most likely but he has been paid to do a job!
