Roof skinned,insulated
Postby Airspeed » Mon Mar 26, 2007 9:13 pm
I got the roof insulated and skinned,got the inside of the hatch skinned and man what a difference it made in the strength, I can pick up one corner and the hatch lifts without the slightest twist.The roof is strong as well,I had to sit on it to staple the sheet down with my gun.I also got the disconect wired in between the hatch and the body,now I can remove the hatch if I need to without cutting wires,I just have to unplug it. Aaron
Airspeed
Images: 16
Airspeed
Images: 16
Postby Airspeed » Mon Mar 26, 2007 9:14 pm
Airspeed
Images: 16
Postby Miriam C. » Mon Mar 26, 2007 9:26 pm
:applause: :thumbsup: Looks great Aaron. The disconnect is a great idea. :thumbsup:
Postby madjack » Mon Mar 26, 2007 10:27 pm
Hey Aaron...ZOOM ZOOM :thumbsup: :D ;)
Hey Auntie M...we use a small, square 6 wire disconnect between the hatch and body...works great.....
madjack 8)
Postby Airspeed » Mon Mar 26, 2007 10:37 pm
I used the same type of disconnect for mine. I thought about using one of those spring loaded contact bars like the ones used in the rear doors of suburbans but I couldnt find one fast enough,probably a good thing! I may just be getting to fancy! Aaron
Airspeed
Images: 16
Postby Geron » Tue Mar 27, 2007 4:57 am
Superb fit on that hatch . . wish mine fit like that.
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Ira » Tue Mar 27, 2007 8:52 am
Geron wrote:Superb fit on that hatch . . wish mine fit like that.
g
It's supposed to fit?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Geron » Tue Mar 27, 2007 9:11 am
g
Absolutely, After you shim here, putty there, beat it with a hammer, re-do the whole thing twice. Sure it fits . . . almost.
g
Geron
Images: 173
