lcurrie wrote:With the urging of my dad who has one of those huge RV/coaches I've decided to go the petcool route.
Can some of you folks that have installed them help us out with some things? We haven't ordered it yet, but we're discussing the hows of the install based on pics and some assumptions we're making.
We plan to install in the galley. We are okay with losing space. In Texas, air conditioning is more important than pots and pans.
Venting:
We assume we need an intake and an exhaust.
On SteveT's (SonnetPro's) build he used boat bilge vents to send the exhaust. Do I need to duct the side to the vent or just put the petcool close to the wall? My dad is thinking if i put it right against the wall, that might be all that is needed.
For intake, do we need another vent somewhere? If so, can someone provide details or pics? Does the air get sucked in at the back where the coils are or on the side at the roundish vent/fan? At night the galley will be closed, of course.
Knobs - did you guys extend the knobs somehow so you could control the petcool from inside? Just put a little door to slide open and use the existing knobs?
Thanks,
lcurrie wrote:Thanks for the info. I think i'm going to put an extra vent in outside of the gasketing so i don't have to leave the galley open. Do you think i would need to do anything special or could i just put one near where it's installed?
With the boat bilge vents do you have any problems with water coming in in a rainstorm?
Thanks for the details on the couplings and the vent dimensions for the other parts. With the exception of the intake vent, i'm going to use your install for inspiration for how to do mine.
Thanks,
Et Cetera wrote:Would it be most beneficial to use insulated hose?
