shock question
shock question
Postby dewayne » Tue Mar 27, 2007 9:03 am
Has anybody ever put shocks on a TSC 5x8 frame. It has 12" tires and slipper springs with 3" clearance between back of wheel and frame, But I would like to also go to a 13" or 14" wheel. I am building a my version of a Weekender.
All help or info would be welcome.
thanks
dewayne
P.S. How do I get Smiles on my post I keep trying to no avail.
Pay it forward and the world would be a better place.
dewayne
Images: 25
Postby SmokeyBob » Tue Mar 27, 2007 9:47 am
Hi dewayne
Can't help you with shocks. :(
For smiles, first check your profile settings and make sure the Always enable Smilies: is checked yes then when you do a post just cilck on the smilies icon that you want to use. Then click on Preview to see if your post is the way you want it before you click on Submit.
Have a great day :)
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
Re: shock question
Postby Dale M. » Tue Mar 27, 2007 9:48 am
Generally you leave cursor where you want smilie :D :D :D
And click on smilie 8) 8) 8) 8) with mouse pointer, ;) you will see a group of mostly punctuation marks, :twisted: :twisted: :twisted: or colon and text and that is the smilie while you are in edit mode.....
Also be sure you do not have disable smilies checked in edit screen and in your personal profile...
Dale
Dale M.
Images: 18
Postby Miriam C. » Wed Mar 28, 2007 9:33 am
not sure if it is a harbor freight but JP Lock did shocks on his. Should be the same process. Page nine has the shocks.
http://tnttt.com/viewto ... &start=120
Postby jplock » Wed Mar 28, 2007 6:01 pm
dewayne,
My trailer is homebuilt with 15 inch tires.
jplock
Keep smiling!
jplock
Images: 233
Postby goldcoop » Wed Mar 28, 2007 7:15 pm
goldcoop
Images: 32
Postby Gerdo » Wed Mar 28, 2007 9:35 pm
Mine is a custom frame but this may help. I added shocks to my trailer after it was bulit. http://tnttt.com/viewtopic.php?t=11291
Gerdo
Images: 156
Postby dewayne » Thu Mar 29, 2007 9:53 pm
Thanks guys.
I think its doable, I just have figure out my top mounting bolt cause my sides are inside the angle. I figurre I will have to weld a bracket on the bottom of angle. bottom bracket I see can be done different ways with no problem. I'm mainly worried about shock length and angle.
:QM :thinking:
dewayne
Images: 25
Postby WarPony » Sun Apr 01, 2007 8:24 am
Here's what I did:
WarPony
Images: 289
Postby brian_bp » Thu Apr 05, 2007 7:32 pm
WarPony, I like the bottom bracket, and I understand the logic of the top mount, but I think I would rather do as the Monroe kit does (the one I used on my trailer) and run the top bolt right through the frame, needing only a 1/2" hole in each side rather than that huge head-clearance hole on the outside. I realize that there's a reinforcing plate on the frame, but it wouldn't be needed with the through-bolt. Was having the head exposed on the outside of the frame rail a problem, perhaps for body overhang?
brian_bp
Images: 9
Postby WarPony » Thu Apr 05, 2007 10:17 pm
brian_bp wrote: Was having the head exposed on the outside of the frame rail a problem, perhaps for body overhang?
Yep, the outside of the body lays RIGHT against the frame so there was no room for a bolt head. I'm not worried about water getting into the hole either because each end of the frame (side rails only) is not capped off. Thanks for the comps on the lower shock mount......... I stole it from Gerdo, though.
Jeff
WarPony
Images: 289
Postby Gerdo » Fri Apr 06, 2007 11:04 am
I thought it looked vagly fimilliar! I've got to run out and check if my shocks are still there. YOU THIEF!
Gerdo
Images: 156
Postby brian_bp » Mon Apr 09, 2007 6:07 pm
Yep, the outside of the body lays RIGHT against the frame so there was no room for a bolt head...
There's always a reason for every design decision...
A slight refinement might be to use a socket-head bolt, which normally has a smaller head and does not need socket clearance around it, to minimize the size of the required clearance hole.
brian_bp
Images: 9
