Using surge protector for power, would it work?
Anything electric, AC or DC
Postby KDOG » Thu Mar 29, 2007 5:10 pm
I'm thinking of using a good surge protector for my electrical needs. So would it work and what would I need? Obviously I need a good surge protector and the external plug. Is that a standard plug or is it a special thing? Also I could've sworn I saw someone here with something like a small "breaker" between the external plug and the surge protector. Would the external plug be generator friendly?
FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
KDOG
Postby sdtripper2 » Thu Mar 29, 2007 5:39 pm
KDog:
KDog wrote:I saw someone here with something like a small "breaker"
You may have been referring to this thread:
http://tnttt.com/viewtopic.php?t=10913
Steve Cox's suggestion:
One of Mikes builds:
I don't think there should be any issues with your generator however maybe
someone else could confirm my thought?
sdtripper2
Search Garoux
Images: 168
Postby KDOG » Thu Mar 29, 2007 5:44 pm
Ok, thats it. Now I just gotta figure out what kind of exterior plug I need and how to wire it to the GFCI and what not. Thanks.
KDOG
Postby Miriam C. » Thu Mar 29, 2007 5:53 pm
KDog the two strips that Steve is showing are GFCI built in. If you look above in Steve's sticky there are pictures of inlets that you hook to your trailer. Mary K did an excellent job with her elect.
http://tnttt.com/viewto ... =14929This picture shows the way she wired the inside. :thumbsup:
Postby sdtripper2 » Fri Mar 30, 2007 3:01 am
KDog:
As Miriam suggests your inlet receptacle can have many configurations.
Some have cable for TV and a square shape. Some are round only for the
male plug inside.
Google search "Charger Inlet" or "Shore Power Inlet"
Example:
http://tinyurl.com/2p4qzp
sdtripper2
Search Garoux
Images: 168
Return to Electrical Secrets
