mix about 20%fiberglass rein with bondo just use bondo harder.
. makes it flow like butter and sand like glass. give more time to work with ( longer cure time) and wont pop from fiberglass
madjack wrote:glassie, what about hardner proportions for the added resin..........
madjack wrote:Kevin, you bring up a good point...my reason for asking questions about this technique, are 1) it sounds good and 2) it's a new technique here and I would like to see it better explained by those with experience using it for all the inquiring minds out there....
toypusher wrote:madjack wrote:Kevin, you bring up a good point...my reason for asking questions about this technique, are 1) it sounds good and 2) it's a new technique here and I would like to see it better explained by those with experience using it for all the inquiring minds out there....
Go ahead and give it a try. Then you can tell the rest of us how it works!
toypusher wrote:I'll give it a go next week one day when I can get some time. I will keep you posted on it.
