Rules for working with styrofoam
Postby Caradoc » Fri Apr 06, 2007 5:17 pm
I couple of things I've learned in the past week as I've been cutting
styrofoam sheets to use as insulation in my teardrop:
1. Don't cut styrofoam in your garage. It makes a huge mess and the
little pieces get everywhere.
2. A table saw works really well and makes nice, quick, clean cuts,
as long as you have the dust collection connected to it.
3. Don't let the dust collection come off of your table saw. It
makes a huge mess and the little pieces get everywhere.
4. A router with a top-bearing trim bit also works nicely to cut
channels in your form for wiring.
5. There's nothing you can do about the router. It makes a huge mess
It all went together really well, but I'm sure I'll be cleaning up the
mess for the next year. Keep the vacuum very handy when working with
styrofoam.
--Lance
Caradoc
Images: 6
Postby Kevin A » Fri Apr 06, 2007 5:27 pm
Lance,
Thanks for posting the tips, great ideas.. :thumbsup:
This is what I used when I cut my foam insulation, it worked fairly well with minumum mess. Not quite as clean a cut as the tablesaw, but it worked ok.
Kevin A
The other guy
Images: 289
Postby toypusher » Fri Apr 06, 2007 7:12 pm
I just used a straight edge and a sharp utility knife.
toypusher
Images: 324
Postby Jiminsav » Fri Apr 06, 2007 7:38 pm
I used gasoline and a blow torch to cut mine.
no, really..used a steak knife..it cuts pretty easy.
Jim in Savannah
Jiminsav
Images: 40
Re: Rules for working with styrofoam
Postby Dale M. » Fri Apr 06, 2007 7:39 pm
Caradoc wrote:I
--Lance
I have seen routers equipped with adapters to allow you to connect a shop vac to router to capture most dust and stuff.... Perhaps you can make a simple one to capture the cuttings...
Dale
Dale M.
Images: 18
Postby asianflava » Fri Apr 06, 2007 8:42 pm
I used the cordless circular saw that came with my cordless drill. It is pretty usless for wood but it did a great job on the foam.
asianflava
Postby Juli n Bill » Fri Apr 06, 2007 10:44 pm
serrated steak knife, cuts with very little mess.
Juli n Bill
Images: 22
Postby Miriam C. » Fri Apr 06, 2007 10:54 pm
:lol: I hear the little pieces everywhere. And they are hot so if you are short they really hit the face hard and hot and get everywhere. :lol:
BTW if you get too much in your shop vac it will smoke forever too. Nasty smell.
Postby doug hodder » Fri Apr 06, 2007 10:57 pm
I'm with Kerry...sharp utility knife and a straight edge, just like cutting drywall, no real dust or other "floaties" to worry about, especially in the finish down the road......Doug
Postby Joanne » Fri Apr 06, 2007 11:45 pm
Doug & Kerry,
Thanks for waiting until NOW to tell us how to cut it. My neighbors thought it was snowing last summer....well...not really, but it made a huge mess and the little pieces got everywhere. :lol:
Joanne
doug hodder wrote:I'm with Kerry...sharp utility knife and a straight edge, just like cutting drywall, no real dust or other "floaties" to worry about, especially in the finish down the road......Doug
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby Juneaudave » Sat Apr 07, 2007 12:06 am
I've been fussing a bit lately with the pink stuff...
I've found a straight edge (I just scribe the curves and freehand) and one of those $1.50 snap off razor knifes works well for a nice fit until about the 5 beers..then the cuts all turn out crooked!!!
No fuss, no muss... :thumbsup:
Juneaudave
Images: 380
Postby doug hodder » Sat Apr 07, 2007 12:16 am
Dave...you obviously spend more time than I do on the insulation fit up...I use the white stuff and if it doesn't fit really well....I just cut a chunk and jam in it....it ain't pretty....Doug :lol:
Postby Juneaudave » Sat Apr 07, 2007 1:08 am
doug hodder wrote:Dave...you obviously spend more time than I do on the insulation fit up...I use the white stuff and if it doesn't fit really well....I just cut a chunk and jam in it....it ain't pretty....Doug :lol:
:lol: :lol: :lol:
Evidently, I spend a lot more time on just about everything, judging the speed of my build!!! You know, I wondered and wondered how some people got their insulation to fit just so. I tried a jig saw to cut out the foam...ok results... but that left a jagged cut that didn't measure up. Then I went to the table saw and it made great straight cuts, but ended up with the perverbial foam snowstorm, and didn't handle the curves...a utility knife worked well, but it didn't get through the 1 inch foam I was using. I finally decided a straight edge and a razor knife worked for me. The razor knife has a long enough blade that it cuts the full thickness of the foam...and if you make multiple cuts with a long, smoothe, perpendicular stroke...you can get a nice fit!!!! Hope this tip from the school of hard knocks helps!!!...Juneaudave
Juneaudave
Images: 380
Postby Caradoc » Sat Apr 07, 2007 1:17 am
If I could do it again, I'd probably use the pink stuff. It's more dense and doesn't seem to look like a bean bag chair just barfed after you cut it.
My first project with this white beaded stuff came as I used a utility knife to cut panels for my garage door a couple of months ago. I swore at it then and at the mess it made, and I never really finished the project. I still had a couple of sheets left over, and I thought I'd use it for the teardrop. My opinion of it still hasn't changed.
Something a little more dense and rigid seems like it'd be a little easier to work with.
I mean, I live in Nevada -- it's always windy. I should have just taken the whole thing outside and did it there. On second thought, a 4x8 sheet would be a little tough to handle in the wind.
--Lance
Caradoc
Images: 6
Postby warsmith » Sat Apr 07, 2007 3:07 am
You could always make a hot wire foam cutter
Hot Wire Foam Cutter
I made something similar to this (Although I used a transformer from a model train set as the power supply)
Like this
warsmith
