Four pins, five wires?
Anything electric, AC or DC
Postby csdivine » Sun Apr 08, 2007 6:11 pm
I have been trying to determine if my trailer is wired incorrectly (which I doubt) or if my U-Haul installed hitch wiring power module has gone bad. The trailer lights aren't working correctly.
But while investigating, I noticed this:
Why would my trailer's factory-installed 4-pin connector have five wires running into it :QM
-- Chris
Build Diary With Pics
"A man can live on packaged food from here to Judgement Day if he's got enough rosemary."
-- Firefly, Episode One: "Serenity"
csdivine
Postby asianflava » Sun Apr 08, 2007 6:42 pm
Two of the wires go to one pin. I think it is the wire that supplies power for the running lights. You want both sides on at the same time.
asianflava
Postby rainjer » Sun Apr 08, 2007 6:44 pm
Make sure you have a good ground on every light on th trailer side.
rainjer
King Koleman
Images: 11
Postby Sierrajack » Sun Apr 08, 2007 6:58 pm
Brown and brown with yellow stripe are connected together.
Yikes, looks like a nuclear melt down.
Sierrajack
Images: 41
Postby Dale M. » Sun Apr 08, 2007 10:24 pm
Sierrajack wrote:Brown and brown with yellow stripe are connected together.
Dont think its melt down, think its just wet...
Dale
Dale M.
Images: 18
Postby Miriam C. » Sun Apr 08, 2007 10:31 pm
Possibly someone installed a new plug. That one looks a bit beat up so check your female side and see if the connectors are spread and not getting a good connection.
Return to Electrical Secrets
