12 volt electrical outlet
Anything electric, AC or DC
Postby Duane King » Fri Apr 13, 2007 5:46 pm
I purchased several stainless steel cigarette lighter style 12 volt outlets that I am about to put into my trailer. They did not come with any kind of schematic. There are two places to attach leads. One is the center post which comes from the center of the plug hole. The other is the cylinder body of the socket itself.
So, which is negative and which is positive? :shock:
Duane King
<img src="http://www.mikenchell.com/images/roadhouse.jpg" >
Duane King
Images: 98
Postby coonrebel » Fri Apr 13, 2007 5:55 pm
Center one is positive. shell is negative
coonrebel
Images: 186
Postby Duane King » Fri Apr 13, 2007 5:59 pm
I don't mean to be negative about this, but are you positive? :lol:
Duane King
Duane King
Images: 98
Postby Dale M. » Fri Apr 13, 2007 6:05 pm
No negative comments so far, I'm positive that the "shell" is negative....
Dale
Dale M.
Images: 18
Postby Geron » Fri Apr 13, 2007 8:58 pm
ats the way I wired mine.
Shell (outside) negative (Bleck)
Center positive (Red)
My Aliner DC was wired with Bleck and White -- White neg. Bleck Pos.
I used a yellow fuse wire for inline fuse which I connected to the white positive. Then I added a on/off switch that had red and black wires to break the battery out of the converter circuit . Just recently sold it. Hope the new owner loves puzzles :? It was wired wierd of that I am positive.
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Micro469 » Fri Apr 13, 2007 10:42 pm
I hate to be negative... but some of you guys are positively wired weird...... :lol:
John
Micro469
Images: 382
Return to Electrical Secrets
