Varnish
Varnish
Postby Signman » Sun Apr 15, 2007 8:35 am
I just finished putting in my inside paneling. I was wondering if I should varnish the backside of the paneling before I put in the insulation. Thanks for your help.
Darrel
Signman
Images: 30
Postby madjack » Sun Apr 15, 2007 9:09 am
D, been lotssa debate on whether to seal or not or add a vapor barrier...it is a matter of choice and perception...we seal everything, inside and out just because we like belts and suspenders :D ;)
madjack 8)
Postby Signman » Sun Apr 15, 2007 10:30 am
Thanks Jack, I will start sealing. I was hoping that I didn't have to seal it. I'm getting tired of the fumes. It's been so cold around here that I can't open the garage door to let the fumes out.
Thanks,
Darrel
Signman
Images: 30
Postby doug hodder » Sun Apr 15, 2007 2:30 pm
You could also try water based outdoor polyurethane....dries quickly, no stink, easy clean up...Doug
Postby madjack » Sun Apr 15, 2007 6:54 pm
doug hodder wrote:You could also try water based outdoor polyurethane....dries quickly, no stink, easy clean up...Doug
...that is what we used on all interior spaces...leaves little or no odor...thinned it about 10% with water and sprayed it on
madjack 8)
