Router Bit Question
Router Bit Question
Postby Mary K » Fri Apr 13, 2007 9:17 pm
I have borrowed a router from a friend to trim the top skin I just installed on my TD. It overhangs about 1/2" on both sides.
What bit do I purchase to do this?
Thanks!!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby rasp » Fri Apr 13, 2007 9:30 pm
Thinking is more interesting than knowing, but less interesting than looking
rasp
Postby doug hodder » Fri Apr 13, 2007 9:35 pm
A laminate trim bit, or a pattern bit...top bearing. And it is one very versatile bit.. Doug
Postby Steve Frederick » Fri Apr 13, 2007 9:36 pm
Hey MK! If you'll be covering the seams in 'glass, use a round-over bit. Hard angles don't work well. If you are just sealing and covering with trim, use the flush bit mentioned by Rasp.
Don't need an expensive one, just get it at the big toy box!
Last edited by Steve Frederick on Fri Apr 13, 2007 9:37 pm, edited 1 time in total.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Re: Router Bit Question
Postby Podunkfla » Fri Apr 13, 2007 9:37 pm
Mary K wrote:I have borrowed a router from a friend to trim the top skin I just installed on my TD. It overhangs about 1/2" on both sides.
Thanks!!
Mk
You need a "flush Trim bit" with a bottom bearing...
Here's a good choise (The shear angle cutting flutes produces a smoother cut than the traditional straight fluted bits.)
http://www.mlcswoodworking.com/shopsite ... tom_anchor
Plus, they only cost about $12. at MLCS. ;)
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby doug hodder » Fri Apr 13, 2007 9:42 pm
Yup...I rethought that...then thought so which end is considered up on the bit...actually looked in a catalog...they don't mention it, just show pics....I use the router in a table most of the time for a lot of work so I just always refer to the top of the bit as having the bearing...my screw up...I should have just posted pics too! Ken...where did your post go? Doug
Postby Mary K » Fri Apr 13, 2007 9:44 pm
:shock: Wow!! You Boy's Like your Bits...lol.
On my next build, I will have a router NO-IFS-ANDS-OR-BUTTS!!!
Thanks EVERYBODY!!! :thumbsup: :thumbsup: :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby RichAFix » Sat Apr 14, 2007 8:25 am
Table saw and a good 2hp (or more) router in a router table and there isn't too much you can't do to wood. Those should be the first tools everyone should buy. Probably the 2 that can do the most damage to flesh also, so be safe!
Listen to what I'm thinking, not what I'm saying.
RichAFix
Images: 10
Postby reiltear » Sun Apr 15, 2007 7:06 pm
In Doug's defence, the router bits with the bearing on "the other top" are indispensable when doing hinge mortises with a proper template - beats the pants off (almost)any chisel in speed and accuracy.
Mary K, as you will soon notice, the routers are an absolute blast to use. The only problem I see is that one develops an addiction to these tools and pretty quickly people amass small collections of them. Since they are not very easy to set up the first time, almost everyone I know who does any kind of woodworking with a router(me too) have several, set up with different bits in them.
My collection, which I'm proud of, includes a Porter-Cable with fixed and plunge base, 1/4" and 1/2" collets; a plunge-base Ryobi with a 1/4" collet and a weeny orange trim router from HF.
The things you can do with a router are only limited by imagination. I've seen people turn fluted table legs using a router and a fairly simple home-built jig.
The only advice I can give you is be careful and try it on scrap first...
You go ... lady! :applause:
Ilya
PS Nothing against table saws either, I'm on my third one...
reiltear
Images: 18
Postby reiltear » Sun Apr 15, 2007 7:15 pm
While boasting of my tools, I forgot to mention another point - look out for shank size, they make 'em different and it might save you a trip if you get a wrong one...
Have fun!
reiltear
Images: 18
Postby Mary K » Sun Apr 15, 2007 7:45 pm
:o :o :o
Oh Great!! Thanks Ilya ! Another addiction. :roll:
Actually...I don't know, dem dar bit's are pricy and I'm a cheepy!! :lol:
BUT, I can see how this one tool could have been useful on making the cabinets :yes: :yes:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Geron » Sun Apr 15, 2007 8:12 pm
doug hodder wrote:A laminate trim bit, or a pattern bit...top bearing. And it is one very versatile bit.. Doug
In response to your sig line about dogs:
http://www-hsc.usc.edu/~cypert/dick/inheaven.html
Read the green poem. I love it.
Sorry, Didn't mean to hi-jack your thread Mary K. But, looks like you got your answer :)
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Mary K » Sun Apr 15, 2007 8:26 pm
That alright Geron, Hijack all ya want! :thumbsup:
I'll even help...
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby reiltear » Mon Apr 16, 2007 12:33 am
Hi Mary K!
I wish I could PM you one...
One of my router bit sets came from the Big Lots around the corner from where I live. I could not tell the difference between it and the set with the "Skil" logo on it(at Lowes), except the price($40 vs $80). They are both carbide-tipped 12 piece sets with ball bearings and include trim bits. Even at $80, a set like this may be worth it, especially if you are planning on using a router on your next build. If you have a HF store nearby, you could give them a shot too.
The "cheepy" bits I have lasted 3 or 4 years already, though if I had a cabinet shop I'd stay away... except for emergencies...
Thanks for letting me rant.
Ilya
PS I love doggies...
reiltear
Images: 18
Postby asianflava » Mon Apr 16, 2007 1:13 am
reiltear wrote:Mary K, as you will soon notice, the routers are an absolute blast to use. The only problem I see is that one develops an addiction to these tools and pretty quickly people amass small collections of them. Since they are not very easy to set up the first time, almost everyone I know who does any kind of woodworking with a router(me too) have several, set up with different bits in them...
That is exactly why I bought a second router (and looking for a 3rd). Once I got it setup to use in my dovetail jig, I said, "I am never removing that bit from that router ever again. It took a few days of experimentation and adjustment to get it to work right.
It was a HF jig, the directions contradicted themselves as far as bit depth. I tried both and neither worked. I ended up starting the deepest it could go then stepping it up in 1/16in incriments. Once I got it close, I had to tweak it in so that they weren't too loose or too tight.
Right now I have one router that I use both freehand and in the table. I'd like to find another to permenantly live in the table.
asianflava
