Keep in mind I have no easy way to carry a 5x5 sheet of plywood home.
Miriam C. wrote:Need a new solution. Putting in extra framing made a boo boo real apparent. I have one rib that is 3/8ths smaller than the others, mostly in this area. Any way to fix this without cutting another?
Keith B wrote:Miriam...why dont' you counter sink some scews into your wood strip and hatch, then sand...if you don't like it at least it's not GLUED and you could try another approach..if it does work, scribe a "set" line, unscrew and apply some glue to make it perm....just a thought before you commit to glue.
Steve Frederick wrote:Is just short on one end?
If so, I would "sister" a section of material along side the offending rib.
If it involves the radius..can you add a thin strip (3/8") to that side?
