Keith B wrote:Thanks Kerry...I'm gonna give it a shot tonight on a little test area... I don't know if the paint is "hard" enough so I'm just gonna do a little test... I think it should work too.. at least it sounds good in writing doesn't it. Thanks for the tips; I'll keep ya posted. I founds some stuff by 3M called Rubbing Compound and Foam Polishing Glaze that said it works on urethane paint, so maybe the stars will align for me... I'm probablly being over anal on this, at least that's why my neighbors said, but still, why not try to do the best you think you can do... I can tell ya for sure I'm going to practice my spray ability for future builds and projects.
Geron wrote:Ony one quick question.
Got my RAKA epoxy. The user manual says mix in 3 oz batches (2 oz resin and 1 oz hardener) Now that only covers about 2 sq feet or so.
Can't I mix in larger batches if I put it in a flat pan to keep the heat down?
What's the largest batch that keeps you from "slangin'" on the last bit before it gets too thick.
Mine has a pot life of about 25 minutes. 'Reckon I could mix as much as 12 oz. at a time???
I'm new at this.
g
Lesbest wrote: When varnishing an old woodie to get that clean finish the last coats are done at 3-4 am and in your underwear so no lint or dust is carried in to float in the air. Hope this helps.
Les
