Window trim advise
Window trim advise
Postby Airspeed » Sat Apr 21, 2007 9:00 pm
I am getting ready to install my windows and thought someone here had advise on this type of window and the trim ring.
I will have to cut the trim rings but has anyone mounted this type of window before?
Airspeed
Images: 16
Postby Airspeed » Sat Apr 21, 2007 9:04 pm
It has a two peice trim ring for the interior but doesnt seem to fit correctly.
I know they will have to be trimmed to fit right but I want to be sure on the mounting technique before I cut the trim,so if anyone has used these
and knows any tricks, I would appreciate any advice !!! Thanks! Aaron
Airspeed
Images: 16
Postby imstriker » Wed Apr 25, 2007 6:42 am
I have one of these on my TD. It was a scratch and dent and missing it's trim and snap ring. I took the easy way out... Drilled 6 holes in the surround, ran small bolts through, sealed, and put nut/washer combos on the inside. I plan to trim it with wood one of these days... Not sure that really helped, but maybe moral support. Good luck.
imstriker
Postby madjack » Wed Apr 25, 2007 10:10 am
Aaron, we use a radiused cornered window similar to yours...they came with a god-awful ugly trim/clamp ring...we tossed it in the al scrap pile...after talking with manufacturer, we drilled holes in the outer flange, put a heavy bead of auto windshield sealant and screwed 'em down with SS screws, which we painted black to match the windows...for trim, we used a 1/2" wide "aluminized" insert T molding on the inside of the cutout that was left over from interior cabinet trim....
madjack 8)
...click the WWW button for more pics.....................MJ
Postby Airspeed » Wed Apr 25, 2007 11:05 am
Thanks, I got it installed with the trim ring,It came out pretty good.
I had to drill holes and cut the ring to fit. Thanks! Aaron
Airspeed
Images: 16
