How much gap do you guys leave around your door? I'm thinking 1/8th"
gap all around,sound like enough? Thanks! Aaron
Airspeed wrote:How much gap do you guys leave around your door? I'm thinking 1/8th"
Geron wrote:Airspeed wrote:How much gap do you guys leave around your door? I'm thinking 1/8th"
You just about have to figure out each build based on the thickness of the trim and hinge offset (hinges are different) . As a general rule 3/8 inch gap on an unfinished door seems to work in most cases. That was too much for my benroy cause I used a plastic hinge (little or no offset) You are working for about a 1/8 inch clearance on the finished door. DRYFIT everything. DRY FIT; DRY FIT; DRY FIT.
DID I SAY DRY FIT????![]()
Cut off a little bit -- mount the trim DRY FIT. If door binds remove trim and cut a little more-- DRY FIT. Continue DRY FIT till it fits. It's easier to cut the excess off the straight sides of the door.
If all else fails get a BIG HAMMER![]()
Did I say DRY FIT????![]()
g
Gage wrote:Geron wrote:Airspeed wrote:How much gap do you guys leave around your door? I'm thinking 1/8th"
And to think all along I thought that 1/4 inch was the norm. No wonder my doors fit so good, I didn't follow the rules again. Oh well, it's to late to do anything about it now. I just happen to think. Now I know why I can't apply any weather seal to my doors. There's no room, but they don't leak so the heck with it.
Micro469 wrote:Geron wrote:Airspeed wrote:How much gap do you guys leave around your door? I'm thinking 1/8th"
g
Geron??? Where do you buy this "DRYFIT"????? Does it work good? You seemed to use an awful lot of it.....
g
