seahorse wrote:Thanks guys.........I was worried about U bolt, and plate strength.
Thats what I wanted to hear.......thank you!toypusher wrote:seahorse wrote:Thanks guys.........I was worried about U bolt, and plate strength.
Should not be a problem, lots of folks have done it before you!!
Arne wrote:Notching works, but be careful you have enough spring clearance. Jack up the FRAME on one side enough to lift the wheel off the ground and see how much you frame/axle distance you have unloaded.. then lower the trailer and see what is left with all the weight on it.
On my 1800# trailer, I did the same thing. Wound up with 2 inches of frame/axle clearance.. worked fine for 10,000 miles till I went through a construction zone, hit a huge pothole, the trailer bottomed out on the axle very hard, and I suffered catastrophic tongue failure (trailer left car)...
The ubolts and plate were never a problem.... I have since relocated the axle under the spring back to it's original position.
Nic wrote:Im thinking notching the frame sounds kinda scary.
