Put on a thick coat, 4-ought steel wool it, re-coat, steel wool, coat, etc... ??
Is it better to brush or roll it on? I can't spray it because of my workspace. I will have to brush or roll. If rolling, what kind of roller?
thanks!!!
doug hodder wrote:Yes you can stain or much more preferred dye, and lay epoxy directly over the wood. Don't use any oil based stains however, I haven't done it but West System recommends against it. You'll have too much money into the project to cut a corner and use some oil based stain from the hardware store and have a problem. I used anilin dyes on my boat, water based, comes in lots of colors, and you can mix them to get the exact color you want. I doctored mine up, and saved the recipe, as well as a sample. Check out www.woodworker.com , go to their stains and dyes. Dyes work great because you can work them with water and a sponge to get the exact color you want if you have an area that is too dark. They are compatible to overlaying with epoxy. Use the top coat hardener. Make sure all sand scratches are out of the wood and that it is completely sanded to the same grit. If going over a soft wood, you may want to lay down a spit coat of 50/50 lacquer and lacquer thinner. Spray it thin or wipe on with a cloth so that it doesn't seal up completely. Most important of all is to do a test patch on some drop wood prior to doing it on the project. The lacquer will help stop excessive penetration of the stain/dye especially on end grain. This shouldn't be a problem if you thin your dye out prior to application. Test first, test first, test first!!! alcohol based dyes are also acceptable... just my experience, doug hodder
Steve Frederick wrote:I bought a HVLP/Gravity spray gun. I was wondering if I could spray spar urethane??? I think I'll try it, or automotive clear coat on my 'Diner..Any thoughts??
purplepickup wrote:Steve Frederick wrote:I bought a HVLP/Gravity spray gun. I was wondering if I could spray spar urethane??? I think I'll try it, or automotive clear coat on my 'Diner..Any thoughts??
Steve, these are some white oak planks in the bed of my pickup that I sprayed with a harbor freight hvlp gravity feed gun. I used Minwax Helmsman Spar Urethane, satin finish. I did it about 10 years ago but I think I thinned it about 10% with mineral spirits. The gun I've got has a 1.4mm nozzle and I crank up the air pressure to about 45 or even 50 psi at the gun to get it to atomize nice.
