doug hodder wrote:Finn...I stack up some wood scraps on top of the wheel to give me the fender clearance I want, then mark the interior flange on the fender with a marker so that I don't have a hole hanging out with nothing behind it...also note bulkheads so you don't end up putting a bolt right into one...drill the holes in the flange. Position it on the blocks again and mark the side of the trailer...drill those holes and bolt it up...at least that's how I do it...others experience may vary....Doug
Tim & Lori wrote:Hi there CF! Glad to see you're back. I've got similar fenders on our tear that I bought from R.W. Johnson. The way Doug described is basically what I did, too. Once I got the location of the fender where I wanted, mostly for clearance and eye appeal, I marked & drilled my holes. The only difference is that I epoxied some "blind nuts" or "t-nuts" on the inside of the camper after recessing them, and THEN put my 1/8" finish birch over them for a clean inside look. Hope this makes sense. Check our our album, there are pictures of the fenders, flanges, fender welting (really adds a nice classic look) and the blind nuts. Let me know if we can be of further assistance. Again, glad to have you back in the loop!!
martha24 wrote:Heikki,
Glad to have you back.
This is the way my husband did it, but I wouldn't call us experts.
We used carriage bolts, because the head is pretty smooth and not too ugly. We used stainless steel, size 5/16 of an inch, not quite sure what is equal in metric.
Others probably do it differently, I don't know???
First is picture of bolt, a little fuzzy but I think you can get idea.
Next is where you see the 4 bolt heads, that part of our teardrop is open at bottom.
Next is a little closer picture of 2 bolt heads
Last picture is taken inside fender of end of bolt with nut and washer.
My husband put a very little rubber spacer between fender and teardrop.
Hope this helps you Heikki. Also if you check my album, you can see my newest pictures. We have taken it on a test drive. You can see the Ford fenders, white wall tires and everything.![]()
Good luck, Martha
Tim & Lori wrote:We used a total of 6 bolts per fender evenly spaced around the flange watch for spars & such on your walls when deciding where to locate the holes. As for the welting, it's all vinyl and gives the fender a more vintage look. It also compensates for any gaps between the trailer wall and the fender itself-a little more work, but I liked the finished (or is it Finnished?) look it gave.
