by rbeemer » Tue May 01, 2007 12:00 pm
Todah,
What you could do is take it to any repair shop and have them pressure test your engine cooling system, this will show where the leak is. I do not think it is your heater core- there wouold mostlikely be coolant inside the vehicle. To blow the fuses makes it seem more electrical, I am assuming that your heater/ac fan still works. Though the fuses may be blowing because coolant leak. I had a water pump that had a leak and my truck never overheated or got close to running hot. I would find coolant on the inside of the fan shroud and on the outside of the water pump but no active dripping.
Hope this helps,
Rick
If ducks had scales, would fish quack?
