With Aluminum and Diamond Plate
Postby Classic Finn » Sat May 05, 2007 1:38 pm
Dear friends
Wether Im using Aluminum or Stainless... If I use Diamond Plate for example on the bottom portion of the hatch about 6 inches or so would I still need to 1st skin it with one or the other above Aluminum or Stainless underneath the Diamond Plate? :thinking: :thinking:
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Miriam C. » Sat May 05, 2007 3:32 pm
:thinking: Hi Heikki. I would bet not but you need to plan how the plate and wood come together. :thumbsup:
Postby Classic Finn » Sat May 05, 2007 4:06 pm
Miriam C. wrote::thinking: Hi Heikki. I would bet not but you need to plan how the plate and wood come together. :thumbsup:
Hello Auntie M.
Can you believe it...were going to start skinning the Voyager Finally.....So nice... ;)
I was thinking it would be sort of double purpose for nothing if it was placed on top of the aluminum but then again I have my doubts ..maybe someone has a logical explanation.. :thinking:
Im using it mainly for protection from rocks ...
Classic Finn
PS Hows that OUCH healing up?
Classic Finn
Images: 146
Re: With Aluminum and Diamond Plate
Postby Joanne » Sat May 05, 2007 7:00 pm
Hi Heikki!
I would skin the entire trailer with the aluminum then add the diamond plate as trim. I say this because you don't want water running down the sides of the trailer, seeping between the aluminum and diamond plate, then starting to rot the wood underneath. If you have completely skinned with aluminum, water seeping between won't hurt anything.
Just my thoughts.
Joanne
Classic Finn wrote:Dear friends
Classic Finn ;)
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby Sierrajack » Sat May 05, 2007 7:45 pm
Heikki,
Joanne said it right on the money. Skin the whole thing then add the diamond plate. Seal the skin and the diamond plate 360 degrees with silicone. Let the silicone dry if it oozes out then pick and rub it off later - much easier this way.
Sierrajack
Images: 41
Postby Podunkfla » Sat May 05, 2007 9:36 pm
Heikki... Well, leave it to me to be a nay-sayer... But, I don't see why it is necessary to double up your siding metal? You can just overlap the diamond plate a couple inches and seal the lap with PL urethane caulk... plus screw the overlap down with stainless screws into a spar. I use the grey colored PL Urethane... It is pretty close match to aluminum. You can wipe off the squeeze-out with mineral spirits or paint thinner. I just think the urethane caulks and adhesives are far better than silicone... They stick better and last longer outdoors. I've been using the stuff about 10 years now to seal things like aluminum framed skylights in house roofs...NONE have ever leaked so far, and that is a pretty harsh environment to test it here in Florida.
friend ~ Brick
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby madjack » Sun May 06, 2007 1:33 am
...Heikki, I see no reason to put yourself thru the hassle of tryng to fit the two different sheets together...skin the whole trailer and then add the diamond plate wherever you want it...I know you use the SIKA products and I agree with Brick about the urethane adhesives/sealants...they just plain work..........
madjack 8)
Postby Classic Finn » Sun May 06, 2007 6:38 am
Thank You Everyone for all the replies.
I will go and skin the entire tear.. then the diamond plate will be the trim.
Ive thought about this seriously now and see the advantages of doing so.
I definitely dont want water going where its not supposed to as mentioned.
Again thanks everyone for the replies.
Regards
Classic Finn..
Back to skinning .. but not without a fresh cup of coffee.. :lol: :lol:
Classic Finn
Images: 146
