toecutter wrote:...Why not just make your axles so they can be moved. Provided you solved the door issue, there is really no reason why not. 18 wheeler trailers have adjustable axle points, why can't TDs?
angib wrote:Elumia wrote:Isn't the obvious answer to haul the ATV on the back?
Nope, it just gives you the same problems, but in reverse.
With the ATV in place at the rear, you need make sure there is an acceptable hitch weight - 10-14% of the total trailer weight is the usual recommendation.
To achieve this, the trailer wheels will have to be right at the back. I've tried some numbers in my trailer balance spreadsheet and the axle may need to be right on the back of the trailer body, with the fenders extending behind the body!
All this works - until you remove the ATV. Then you are back to having a hitch weight of 300 pounds or so, because the trailer wheels are so far back.
If you never want to move the trailer without the ATV on it, there's no problem...
Podunkfla wrote:... I have yet to see a design that I liked of any kind of hybrid tear/hauler where it fit inside? All the ones I have seen either made for an awkward bike hauler or compromised the galley too much ...
eamarquardt wrote:... Haven't decided how to mount the fenders to the axle or angle so they moves all together but that should't be tough ...
