kerryd wrote:Wolfix , Are you saying 3" sq. tube 3/4" side walls ? Kerry
TRAIL-OF-TEARS wrote:Yes, a steel frame can be made lite. I could pick up my frame, with wheels, to turn it over.
kennyrayandersen wrote:dovaka
Where did you get your torsion axles, and did you weigh them before installation? My trailer should be 500# loaded up and I'm looking for some very light-weight axles. Did you use the half torsion type?
A note on Al vs. Fe Aluminum is lighter but costlier. Even though I'm shooting for a completely crazy light weight, I haven't signed on to aluminum because it is quite expensive. I haven't completely given up, but I think I'd have to find some surplus at a really cheap price before considering it.
Here is part of the problem. If it's good aluminum -- high-strength aerospace alloy (7075, 7050, 2024 etc.) then the ultimate stress can run as high as 70+ Ksi (kips per square inch), which is double what mild steel is run up to (high-strength steel is another story, but it is really expensive as well). Aluminum is one third the weight, so it's not hard to see why we build airplanes out of aluminum rather than steel (for the most part). However this type of aluminum generally welds very poorly. The stuff that welds well, isn't as high strength (6061, 5052 etc). So the building techniques have to be specially taylored to the material.
The advantage of using low-strength steel, is that is is very cheap, and it can be readily welded. If you are careful about where and how you put the metal, you can save some of the weight by using proper design priciples.
angib wrote:Kenny,
As you're an aircraft engineer, you should know all about fatigue strength, which is why aluminium isn't as attractive for a trailer as it might first seem. Most trailers don't get a crack inspection every year, which is the minimum you'd need to keep it safe. Aluminium was used briefly for the frame on a fiberglass trailer and they now display the cracking problem that you'd expect.
But if you're intending to make a sandwich composite bodyshell, why do you want a frame at all? John (?) at Tiny Tears has built a frame-less composite teardrop (though he foolishly overlooked the peel strength of the suspension mounts!) and we've discussed this idea for a wood body before. Here is my design for a frame-less Ultralight:
The red bits are the metal used to transfer the loads from the coupler and suspension into the body - but with composite construction it would be easy to chuck a bit of carbon in at these points and have no metal at all.
Andrew
