shamrock wrote:Sorry I was not clear about what I ment when I said "run it thru my frame" . I ment drilling holes thru my cross members, sliding it thru and tack welding in place.
Keith ...I would like to know more about this flexible SS tubing, like any place I can see and of corse get it ?
Thanks Scott
Keith B wrote:Copper will work just dandy. Soft copper is typically used for "refrigerant" lines, so just make sure you get the appropriate fittings for the job, because 1/2" soft copper and 1/2" ridged coper do not take the same fittings.
