If you keep a running tab of the wood you put in you will be able to keep the weight low.
Now go make sawdust
Model_A Bill wrote:ok....you talked me out of 5' height.![]()
I'll build it on top of the trailer instead, that is a good alternative.
I'd really like to keep it to 1000#'s or less. Who cares if you can see the trailer!![]()
So...It will be the benroy with the 5x8 trailer, the 4 ft. height by 5 ft. wide by 8 ft. long.
Will this meet my weight requirements?
All in favor...............................????:thumbsup:
I know, I know , I know...it's my decision to make but I NEED YOU!!!!!!!!!!!!
wolfix wrote:You guys work?
Model_A Bill wrote:Well Ira.....
Which ever one weighs less.
Which would you recommend?
btw, I love you too
angib wrote:wolfix wrote:You guys work?
It's where they go to do the design, web research and forum participation for their teardrop, as far as I can tell......![]()
Andrew
For a lot of folks, that really cuts down on your options.
Model_A Bill wrote:There is a HF near me but NOT a NF. I went to their website and I don't see a trailer there that is a 5x8. They list a 4x8 but the capacity I think was only 970 lbs. I don't think that that would be hevy duty enough but I could be wrong.
Is there another web site for NF???For a lot of folks, that really cuts down on your options.
And why would this cut down on my options?
See what you guys started...I have soooooooooooooo many questions!
Model_A Bill wrote:Thank you martha, that is good advice.
I like the fender you have there as well as the spoked wheel. That would probably be a very similar look as to what I want.
It's gonna be real tuff finding 4 lug wire wheels. Ya might want to rethink
about a custom frame with an axle that will accomidate the wire wheels.
Maybe you ought to approach this like building a house "from the ground up "
Model_A Bill wrote:it might be a better option to build a trailer.
Jack J wrote:Bill,
Is this what you are looking to end up with? This is a friend of mine that built his to pull behind his stock '29 A.
