Shelly is also bringing the 20"er for me.
doug hodder wrote:Dean...if that's the case...the site that Kevins trailer was in might be a good one...it sits a little higher than the one we were in last year, and we can cram in 6+ trailers in it....and no one uses those showers back there hardly, maybe get those 2 spaces together? Or are you off to the hinterlands? Doug
WoodSmith wrote:I like it! Just one question, what is the capacity on those hinges? It would really suck to be boiling pasta or corn or crab or you name it on the right burner and hear cracking. A hot stove falling with a large pot of boiling water on top would be a nasty thing to try to catch. And tough to overcome the instinct to try to catch it.
Again, I like the concept, and the hinges may be up to par, it's just tough to see them in the pic.
bledsoe3 wrote:
I also built the folding windscreen (Thanks Joanne) for my DO table and thought I better give it a test run.
bledsoe3 wrote:I did a little remodel on the galley. I built the galley around a cooler I had. It was too small and I replaced it with a bigger and better cooler. I was using the old one for storage but it was not a good use of space.
Stove in place.
