Juneaudave wrote:Ouch, Auntie M...all that math makes my head hurt!!!![]()
Miriam C. wrote:Smart A$$.![]()
The only math in that is the 8 inches needed for my board width. Mine needs an adjustment on the top cut but I really think I can just put it there and mark it.
BrwBier wrote:On my trailer I don't see how all joints could be 90 degrees without the boards being so wide that the waste would be hard to accept. Each trailer will be different and each persons tolerance for the amount of waste is different. I would think that the joints would be 1/2 of the meeting angle of the two pieces.
Brwbier
Miriam C. wrote:BrwBier wrote:On my trailer I don't see how all joints could be 90 degrees without the boards being so wide that the waste would be hard to accept. Each trailer will be different and each persons tolerance for the amount of waste is different. I would think that the joints would be 1/2 of the meeting angle of the two pieces.
Brwbier
Well, you use the left overs for the straight runs.and all the other little shelves and stuff.
apratt wrote:Miriam don't you think that would be easier? I thought it was a good idea. Thanks Steve.
