A hop-skip-bounce
Postby Keith B » Sat Jun 02, 2007 10:34 pm
Ahhh, :lol: now that's "Kansas" talk.. hook it up and never look back. :lol: Thanks everyone. I'm sure it's just the way it is.. just kinda shocked at what I saw in the mirror.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby madjack » Sat Jun 02, 2007 10:39 pm
Keith...if the wheels aren't leaving the ground, then that "bounce" you are seeing is the torsion axle doing it's job.....
madjack 8)
Postby Gage » Sat Jun 02, 2007 10:42 pm
Oops, I missed the fact that you had a torsion axle. Danny is probably more right than I am. Have you got a friend that would follow you around the block?
Image Image Image
Gage
Images: 28
Postby Keith B » Sat Jun 02, 2007 10:47 pm
I sure do have a "chaser"... that's the plan for tomorrow. Tow and follow. The TD was leaving the ground before I added the rock, etc. to simulate galley, etc... but now, it's just "bouncing", not leaving :)
Keith
Keith B
Postby bledsoe3 » Sun Jun 03, 2007 12:06 am
Gage wrote:Oops, I missed the fact that you had a torsion axle. Danny is probably more right than I am. Have you got a friend that would follow you around the block?
You didn't speed read a post did you? :shock:
bledsoe3
Images: 112
Postby dhazard » Sun Jun 03, 2007 12:17 am
Keith, have you checked the tire balance? I had to go with a 2300lb torsion axle to get the same bolt pattern as my Camaro’s. I am running 27lb pressure in the tires and it gives a nice smooth ride.
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby Woody » Sun Jun 03, 2007 12:18 am
One thing I have noticed when traveling pulling or even following a Teardrop is that the bounce appears greater looking back at the trailer in the mirrors than it really is sometimes. The movement or oscillation of the tow vehicle amplifies the appearance of the "bouncing" in the mirrors sometimes. They are going to bounce alittle. I have 0ver 17,000 plus miles on one of them and not one structural problem what so ever. I have been concerned on all the crap (additional weight) my wife feels necessary to bring along. All my teardops have 3500 lb straight axles, which allows for car wheel and tire usage, with 1150 lb spring packages installed for off road use in our area. Reducing tire air pressures does smooth out the ride and gives more cushion to the teardrop riding behind the tow vehicle. However I would not recomend this if your using China poppers only with larger car style wheels and radial tires. Most Trailer rated radial tires have stiffer sidewalls, not rated for smoothest ride verses car radial tires which flex more for comfort. Just my two cents worth
Woody
E-mail: [email protected]
Woody
Images: 26
Postby Gage » Sun Jun 03, 2007 12:37 am
I don't speed read. I also don't read a lot of posts. At least I admitted that. That's more than I can say for a lot on this board.
And how's that saying go? If the shoe fits, wear it.
:lol:
Image Image Image
Gage
Images: 28
Postby bledsoe3 » Sun Jun 03, 2007 1:18 am
:lol:
:lol: :lol: :lol:
Did you get the e-mail I sent to your sbg account?
bledsoe3
Images: 112
Postby Gage » Sun Jun 03, 2007 1:58 am
bledsoe3 wrote: Did you get the e-mail I sent to your sbg account?
Yep, I'm doing some checking. I had a sign shop do my Dalton.
Image Image Image
Gage
Images: 28
Postby bledsoe3 » Sun Jun 03, 2007 3:05 am
Thanks Gage!
bledsoe3
Images: 112
