Good deal there Steve. 2200# springs eh. Think they will be to hard?
Your setup is very similar to the USMil M101 3/4 trailer. The springs are multi-leaf, thin, have greasable bolts at both ends. I've got one and will be using for my Pinzgauer ambulance box transition. It needs a little extension to fit the box.
I'll be eliminating the axle and several leaves, relocating the leaf pack back using the stock hardware, welding the tongue and adding a single coupler bar similar to your layout. I'll be using a Dexter 3500# parking brake axle under/on top of the leaves (haven't figured out the weight just yet) with 14" tires (free wheels/tires given to me).
I noticed your frame is boxed all around. Think it was necessary? M101 is 'C' channel and the only crossmember boxed is the one over top the axle. The original trailer box was secured to the outer side of the frame with 90* brackets. Maybe the box had enough stiffness in it to add to the rigidity of the frame.
What is the length of your spring pack following the top spring curve?
Looking forward for me pics.
