I am wondering if I should use laminated spars for the roof. I intend to give it a slight dome it to give it strength.
Has anyone built a wide drop. I see 4' to 6', but I'm wider yet.
Thank you for your input...
Pat
plbecker wrote:I was going to use 2x2 is that too big?
plbecker wrote:I was going to use 2x2 is that too big? I was going to use them in the wall section so I can reuse the old trailer windows.
Pat
Ira wrote:If you're running 1 by 2s the tall way and not flat for a 1 3/4" height, do you really need 2 by 2's?
Jst83 wrote:Ira wrote:If you're running 1 by 2s the tall way and not flat for a 1 3/4" height, do you really need 2 by 2's?
Just my thoughts again but I think the longer the span the beefier it should be a 1x2 would be 3/4 x1 3/4. I would think the 3/4 width would get wobbly over the 7' span and wouldn't remain as stiff as needed . again just the ramblings of an amateur
