What do you use at the scarf joint on the out side to keep the roof from leaking. Epoxy and glass tape or....?
Thanks !
Jason
Geron wrote:PL Urethane to stick it together (and waterproof)
Didn't think glass was necessary 'cause, (I think) it's main purpose is to strengthen the joint and that joint is strong enough on it's own.
g
kirkman wrote:Thanks Guys. I ended up Using west systems 105-a epoxy and glass tape. Just to make sure nothing came apart or leaked!
kirkman wrote:Night cap.... You could have feathered it in( like you would with bondo) with resin mixed with airocell thickener.
