Thinking of doing graphic wiring diagrams...need input
Anything electric, AC or DC
Postby asianflava » Sat Jun 16, 2007 11:09 am
I'd put the master circuit breaker/fuse before the positive bus.
asianflava
Postby Dale M. » Sat Jun 16, 2007 11:36 am
asianflava wrote:I'd put the master circuit breaker/fuse before the positive bus.
Good point.
I have to agree with this!....
Dale
Dale M.
Images: 18
Postby brian_bp » Sat Jun 16, 2007 8:47 pm
Dale M. wrote:...Also as for VOLTAGE drop.......Is anything we put in a tear that critical for voltage drop...
Generally not, but that drop is also energy wasted, and battery endurance is a factor for most people who are camping and using battery power. I would rather use a bit larger wire than carry a bigger battery or more expensive solar panel area. Everything is a compromise, of course, and bigger is not simply better, in wire size or anything else.
brian_bp
Images: 9
Postby bdosborn » Mon Jun 18, 2007 11:34 pm
I think you could keep everything a lot simpler but just using #12 wire throughout. The voltage drop in a #12 wire at the lengths seen in a 10' tear is less than 5% at 20 amps. It seems a shame to make a simple visual diagram and then obscure it with voltage drop calculations. I would just pick the wire and fuse sizes and be done with it. Otherwise you'll be explaining how to size wire for load and voltage drop to people who just want a wiring diagram.
Images: 778
Postby Kankujoe » Mon Jun 18, 2007 11:45 pm
Les,
I think it is extremely helpful to me (others too) for you to continue with your graffic postings. Seeing the actual components will certainly be useful for me as I move into this phase of my trailer project.
Joe
Ad-ven-ture: 1. an undertaking involving risk, unforeseeable danger, or unexpected excitement. 2. an exciting or remarkable experience. Trav-el-er: 1. one who seeks to experience their world. 2. one who seeks to be immersed in other cultures.
Kankujoe
Adventure Traveler
Images: 19
Postby Kankujoe » Tue Jun 19, 2007 12:13 am
madjack wrote:Les...some advice...K.I.S.S.........give some links to the more technical/esoteric side of eletricity................. 8)
Les,
I'd keep in BOTH the simple & more detailed information in your postings. I would rather become familiar with this technical stuff in the context of MY specific application (TD/TTT elecrical systems). For me that is the K.I.S.S. approach. I tend to get sidetracked or lost in information (more technical websites or sources) and lose sight of what I'm trying to do in my own application.
Not to argue with MadJack... but IMO your approach is more simple to me than referring me to other sources where I must first wade through stuff I am not familiar with to find (if I can?) what info I actually need.
Joe
Kankujoe
Adventure Traveler
Images: 19
Postby Nitetimes » Tue Jun 19, 2007 12:15 am
Here we go again! :roll: :roll: :roll: :roll:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Tallguy3578 » Tue Jun 19, 2007 9:41 am
Great idea! :thumbsup:
Looks good so far.
I want to share something with you: The three little sentences that will get you through life. Number 1: Cover for me. Number 2: Oh, good idea, Boss! Number 3: It was like that when I got here.
Tallguy3578
A Image from RVsolarelectric
Postby Guy » Tue Jun 19, 2007 2:32 pm
Dear Les,
Here is an image from http://www.rvsolarelectric.com . I think the catastrope fuse is quite important.
Regards,
Guy
Guy
Images: 44
Return to Electrical Secrets
