Plastic Hinge install questions - Pictures and Q's added
Postby Mary K » Wed Jun 20, 2007 10:39 am
I have purchased the Plastic Hinge from McMaster-Carr for the hatch and I need some help on the trim covering it.
I have a drawing to help.... Remember I am using WOOD trim, not alum and I would like to countersink the screws and use plugs.
Do I have the right idea on how to do this?? If so, what would you make dimensions A, B & C?
Thanks for your help.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Re: Plastic Hinge install questions
Postby Geron » Wed Jun 20, 2007 11:57 am
Mary K wrote:I have purchased the Plastic Hinge from McMaster-Carr for the hatch and I need some help on the trim covering it.
Mk
Mary K,
I'd make "C" wider. The space between the trim where it meets in the middle of the hinge (where the dimple is) has to be as far apart as possible else it will restrict the opening of the hatch. Seems you've already realized that since one piece of trim is beveled. You may have to bevel both pieces of trim. I'm really not sure how you'll do this since I used 1/8" aluminum and the opening of the hinge is still restricted somewhat by the two pieces of 1/8" AL meeting when the hatch/door is opened. Just experiment I guess. I just Dunno :QM
With "C" wider you can move the trim back closer to the edge of the hinge to allow more opening room, However, the mounting screws need to be at least halfway between the edge of the hinge and the dimple. Again, a real puzzle, I just Dunno. At first consideration seems physically impossible to use that thick a molding.
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby madjack » Wed Jun 20, 2007 12:28 pm
MK, we used 1/2" AL flat stock for that purpose....but I will give an answer...first off, Like the mighty G said, you may have to(very probable) bevel both sides... and be sure to seal EVERYTHING, inclusing screw holes...A) 1", B) 1/2", C) 1/4" ...I would take these numbers under consideration and wait to see if Steve Cox has an input here, since he did his in a very similar way...
madjack 8)
Postby James & Avisia Flohr » Wed Jun 20, 2007 2:20 pm
Wouldn't you place the dimple down for more range of motion? :thinking: Jim
'Live, Love, Laugh and Be Happy'
Postby Mary K » Wed Jun 20, 2007 2:48 pm
Mighty G & MJ, Thanks. At least I am on the right track. Good! Just trying to get my head wrapped around it, ya know.
Jim, :thinking: I have thought about that, I just went with what McMaster showed as being the "TOP".
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Geron » Wed Jun 20, 2007 3:06 pm
madjack wrote:MK, we used 1/2" AL flat stock for that purpose....but I will give an answer...first off, Like the mighty G said, you may have to(very probable) bevel both sides... and be sure to seal EVERYTHING, inclusing screw holes...A) 1", B) 1/2", C) 1/4" ...I would take these numbers under consideration and wait to see if Steve Cox has an input here, since he did his in a very similar way...
madjack 8)
Was the Al stock 1/2" thick? or 1/2"wide x 1/8" thick? I'm still having difficulty understanding the range of motion with 1/2" thick molding.
I had some shoe molding left over and it's "roughly" 3/8 x 3/4".
So I experimented some. With the squared side of the shoe molding inside and on top of my 1/8"(B thickness) flat AL (that'd be 1/2" total thickness for "B") the door would open just under 90 degrees before binding occurred.
Turning the Shoe molding over still with "B" at 1/2" but with the bevel on the shoe molding inside the binding started at just over 90 degrees. So that would be "doable"
With just my 1/8" flat Al the binding starts at about 135 degrees.
Yes I did put the dimple down on mine.
Looking forward to Steve's input.
g
Geron
Images: 173
Postby Geron » Wed Jun 20, 2007 3:22 pm
OK OK OK, DUH DUH DUH, READ the Schematic Mighty g.My bad, My bad
You got the 2" hinge and I used the 1.5" hinge. That'll give you plenty of gap. Much more than I'm experimenting with. Go fer it, girl.
g
Geron
Images: 173
Postby Mary K » Wed Jun 20, 2007 3:29 pm
:lol: You okay Geron? :D
I have temporary installed mine with the dimple up and I am having no problems with it so far. But we will see what Steve did.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Geron » Wed Jun 20, 2007 3:36 pm
Mary K wrote::lol: You okay Geron? :D
Mk
I've never been "OK" but have managed to maintain a status of "living" as opposed to "dead" for 61 years :o :lol: :lol: :lol: :? However, that is currently being debated by my wife and boys.
g
Edited: Don't think it'd make a dab of difference dimple up/down. Opening radius determined by the molding anyways.
Geron
Images: 173
Postby madjack » Wed Jun 20, 2007 11:10 pm
madjack 8)
G, the al stock was 1/2" wide X 1/18" thick...sorry for any confusion...we also left the "dimple" area free and clear by a full 1/4" on both sides............
madjack 8)
Postby Micro469 » Fri Jun 22, 2007 9:31 pm
madjack wrote:
madjack 8)
madjack 8)
What about sealing it ? Put sealant under the hinge, on top of the hinge, both,, and what kind of sealant? :thinking:
John
Micro469
Images: 382
Postby Steve_Cox » Fri Jun 22, 2007 10:09 pm
Hi Guys,
Sorry I haven't been paying attention :oops:
Uhhhh....dimple down.
Any sealant but silicone.
The more wood to wood contact behind the hinge the better the waterproofing, guess that's about it. I used the 2" hinge and the wood strips were 1.5 wide with a 3/4" wide rabbit for the hinge to sit under(does rabbit have 2 T's?)
Steve_Cox
Images: 196
Postby Micro469 » Fri Jun 22, 2007 10:29 pm
Steve_Cox wrote:Hi Guys,
Hi Steve... just finishing my hatch, I routed out my first layer of my roof and hatch so the hinge will sit flush with the roof. Plan to cover it with wood,and screw it down. Should I put caulking or sealant under the hinge, or just between the hinge and the wood on top. What would be the best sealant?? :thinking:
John
Micro469
Images: 382
Postby madjack » Fri Jun 22, 2007 11:32 pm
John, I would use a urethane based sealant/adhesive, such as is used for windshields or one of these from SikaFlex
I would apply the adhesive, above, below, behind, on top and anywhere else that water could possibly get to...that includes squirting some in the screw holes as well....
madjack 8)
Postby Micro469 » Fri Jun 22, 2007 11:38 pm
Thanks MJ... :thumbsup:
John
Micro469
Images: 382
Users browsing this forum: Bing [Bot] and 6 guests
