Layout of bulkhead, galley, and inside cabinets??????
Postby sandman » Fri Jun 22, 2007 10:36 am
Hey Folks,
I am just getting into finishing up framing for my Fantastic Fan. After that's done, I have no clue what to do next. I am working off no plans at all but my ability to think outside the box is very limited. I have posted a basic drawing of the profile that I am using which is almost identical to the Little Guy Sport. I have no measurements as to where to begin and end the hatch or install galley shelf, bulkhead wall height, or placement, or inside cabinets. Does anybody know of a plan that I can use as a reference to help me finish out the rest of my tear?
I looked through the library but nothing really comes close. Hmmmmmm...What to do next????
sandman
Images: 154
Postby Mary K » Fri Jun 22, 2007 10:39 am
Sandman, at the top of the page there is a link to the Generic Benroy Plans. This should help you on your build. :thumbsup:
Mk
Ps...Ya might want to bring that door opening down a little. put it closer to the TD floor....oops...I see you have already cut them out.. too late..... :o
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Ira » Fri Jun 22, 2007 11:07 am
Your bottom bulkhead wall/framing should be 6' back from the front, which will give you 6' of sleeping length. According to your profile, that also means 13 3/4" from the back edge.
Are you following this at all?
Once you got that down, you can decide to place the middle and upper ones wherever you want, depending on what you want cabinet-wise in both the cabin and galley.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Miriam C. » Fri Jun 22, 2007 11:41 am
Bottom bulkhead wall should meet the mattress with tuck room. After that go up 18 to 20 inches for foot room. It can be less if you have really small feet 8) out from that line to where you want the upper cabinet to land. Be sure you leave yourself breathing room. I would take some cardboard in and see what I could live with.
The Benroy plans have a great lay out you can modify if needed
Postby sandman » Fri Jun 22, 2007 1:47 pm
Yeah, I like the Benroy Plans and still have them printed out from when i was originally going to build one. I am just terrible at trying to take the layout from the Benroy and figuring where and how I should set it up in my profile.
Hmmmmmm. Maybe I could lay the Beroy Plans on top of my drawn profile and study it that way. I am a VERY visual person and need something definate to go on. UGggggggggg!!! Lord of Teardrops, please help pitiful me!
I plan on using a queen sized mattress which is listed at 78" length.....Should I install my bulkhead like 80" from the front???? That would leave roughly 4 3/4" of flat floor before the floor starts to curve up. I was going to have a thin storage area accessible from the galley where you pull open part of the countertop to access the small compartment...Does this make sense?
I wonder if a 20" tall bulkhead wall installed 80" from the front will be a good place to start????? Hmmmmmmm just wondering if this could create any problems for the rest of the build. :cry: :cry: :cry: :cry: :oops:
If I put in a bulkhead, what is the best way??? Frame it or just cut a 3/4" thick plywood to size and screw into it from the outside???? Is 3/4 plywood too thin to drive screws into the edges???? Will I crack it or get tear-out? I plan on Gorilla Gluing the bulk head wall just need to figure the rest of this confusing crap out.
sandman
Images: 154
Postby Alphacarina » Fri Jun 22, 2007 2:19 pm
sandman wrote:If I put in a bulkhead, what is the best way??? Frame it or just cut a 3/4" thick plywood to size and screw into it from the outside???? Is 3/4 plywood too thin to drive screws into the edges???? Will I crack it or get tear-out? I plan on Gorilla Gluing the bulk head wall just need to figure the rest of this confusing crap out.
I'm going to use 3/4 ply for everything, but cut it about 3 inches short and then glue/finish nail some 3/4 by 1 1/2 inch strips of oak to the edges, so I'll have something to glue/screw it to the sidewalls with
Don
Alphacarina
Postby Chuck Craven » Fri Jun 22, 2007 7:02 pm
Like This? I took some assumptions when drawing it.
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby sandman » Fri Jun 22, 2007 7:18 pm
Whoa!!! Very nice!!! I am not creative enough to do that...Very well done. That looks VERY VERY close to what I want. Dude, thanks for drawing that out. I do believe that will work. I will print it off and take it to the shop and make some measurements. Thanks for helping me out. I owe you one!!! :thumbsup: :thumbsup: :thumbsup: :applause:
sandman
Images: 154
