warped luan plywood
warped luan plywood
Postby Arne » Sun Jul 01, 2007 1:28 pm
I cut the walls out of luan plywood with 3 layers (just under 1/4" thick.)... it got a pretty good warp into it, enough so I have to weight it down to work on it....
I'm building my first wall a section at a time and keeping it level while the glue dries... not sure I can salvage it or not..
Is luan particularly susceptible to warping?.. this was not in the sun and was laid out flat on my work bench....
Anyway, have started to work on it to see what happens.. the other 3 sheets are laid on the floor trying to straighten them out.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Jiminsav » Sun Jul 01, 2007 3:19 pm
Arne, I used 3 ply luan on my projects and didn't have too much of a problem with warpage.
on a positive note, maybe the warp will help when you put it on a curved surface.. :? 8)
Jim in Savannah
Jiminsav
Images: 40
Postby Arne » Sun Jul 01, 2007 5:17 pm
I found if I turn it over, I think I can get most of it out.. then the studs might finish it.. but it has all kinds of twists in it.. could be the weather.
So, I flipped it over and will see what it looks like in the a.m.... maybe I can catch it while it's almost straight./g/.
I'll take a pic tomorrow.
Arne
Mr. Subject Line
Images: 96
Postby Podunkfla » Sun Jul 01, 2007 6:29 pm
Arne... I found the easiest (lazy guy's way) way to get the warp/bow out of plywood is to lay it out in the sun, crown side up, on the grass... It seems the humidity from the ground swells the tight side and the sun dries the swelled side. Works pretty good & fast most of the time. :lol:
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby mikeschn » Sun Jul 01, 2007 7:31 pm
What happens if you glue some sticks and insulation to the luan? That should straighten it out.
Postby Arne » Sun Jul 01, 2007 7:39 pm
The curl on the long edge is kind of remarkable, maybe 2 inches up, from about 1 foot in... I've never seen ply go like this so quickly.. we have had some hot weather, but the ply has been inside the garage (which may have been up to 100 degrees, come to thing of it). Last two days have been in the 90s.
I may try putting it out in the sun to see what happens... using weights, I can get one section straight at a time, but it makes for slow going on the build... I don't have that many heavy things.. may resort to water in 5 gallon buckets.
I'll give you an update after I work on it tomorrow.. and try to get a pic or two.
Arne
Mr. Subject Line
Images: 96
Postby Micro469 » Sun Jul 01, 2007 11:32 pm
Still got your receipt??? Take it back and get new ply. Any big box store will exchange it.... They know they sell crap to begin with..... :roll:
John
Micro469
Images: 382
Postby Arne » Mon Jul 02, 2007 5:53 am
I don't think they would like the tear drop shape it has/g/... well, maybe.
Arne
Mr. Subject Line
Images: 96
Postby Arne » Mon Jul 02, 2007 11:09 am
I found out a 5 gallon bucket 1/2 filled with water makes a great weight to hold down warped plywood, as long as you don't go to the other end and "make an adjustment"... then it just makes a big mess.....
Arne
Mr. Subject Line
Images: 96
Postby pauld3 » Mon Jul 02, 2007 11:17 am
we weighted ours down and once we installed it, you could not tell there was any warpage! Now that's a good word for our tear drop dictionary, "Warpage."
I had a pair of jeans that did this too when I washed them, found out later they were seconds...maybe your plywood wasn't the grade it was sold as...you know what I mean??? 8)
Lynn
Paul & Lynn Donovan
The Toad Drop Inn
Liberal, KS
pauld3
Images: 94
Postby Arne » Mon Jul 02, 2007 12:50 pm
P&L, I'm finding that once I get some wood glued down on it, it lies flat enough so I think when I glue the opposing skin on and weigh it down it should be okay...
I'm gluing one or 2 pieces per day, so hope the next wall goes quicker..
Nest time, I'm going to start with a piece with curl down on the edges instead of edges curled up... I think it will work better..
But, I am making progress.... albeit slowly.
Arne
Mr. Subject Line
Images: 96
