the jelly belly build
Postby del » Fri Jun 29, 2007 9:47 pm
Hi every one, the curves amaze me, how in the world did I do that? Maybe I should have built a weekender, naw I like this one called the jelly belly.
Progress;
A little sanding and I should be able to put on the lower skin.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Fri Jun 29, 2007 9:56 pm
Les until the skin is put on the counter support is weak, plus i need to add more structure under my someday counter.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Jun 30, 2007 10:48 pm
I went out and fought with the rear skin today. One spar popped off and the top brace twisted. But it is on, will see, if I can fix it tomorrow when I remove the clamps.
If I can not fix it run out in the middle of a field and scream.
del
del
5000 Club
5000 Club
Images: 410
Postby martha24 » Sat Jun 30, 2007 11:13 pm
del wrote:Hi every one, the curves amaze me, how in the world did I do that? ..........
del
If they amaze you, they amaze me times 10. :? I don't quite follow how your galley is going to work, but as you get farther I'll come to understand. :lol:
If you ever did just a simple teardrop, the hatch would seem like absolutely nothing. :lol:
Just amazing. :applause:
Martha ;)
Martha ;)
martha24
Images: 237
Postby Laredo » Sun Jul 01, 2007 11:38 am
I like how you're bracing your spars below the "waist" of the tear but I'm worried that you're not seeming to brace above there too (say about 18'' down from the top joint of the spars). I think braces there would help prevent the skins from pulling/twisting/torquing the spars?
Laredo
Postby del » Sun Jul 01, 2007 12:37 pm
Laredo everything below that brace is part of the body. I still need to install a brace 1/8" (I think) above that, that becomes part of the hatch. The spars above the lower brace in time will be cut, and become the structure for the hatch (to be skinned first). Does that make more sense? (If this makes sense please explain it to me, just kidding.) The twisting is due to where the strap clamps were attached, next side they will be hooked elsewhere.
del
del
5000 Club
5000 Club
Images: 410
Postby Laredo » Sun Jul 01, 2007 9:54 pm
OK ... but, I like what I see on your build.
I just think, for no reason I can explain, it needs more internal braces. Maybe I'm not giving the skin curve enough credit as a strengthening force.
Still, I can see how building something that complex would be fraught with temptations to run out into the parking lot screaming, some days.
Laredo
Postby del » Wed Jul 04, 2007 6:14 pm
In the last couple of days (it is over a 100f today) I have trimmed the tail skin I installed the other day.
I also reinstalled the spar that popped out when I put the skin on. now is time for my nap.
del
del
5000 Club
5000 Club
Images: 410
Postby peggyearlchris » Wed Jul 04, 2007 7:54 pm
:) Del, I sure enjoy following your build. :thumbsup: :thumbsup: Peg
peggyearlchris
Images: 56
Postby Mary K » Thu Jul 05, 2007 10:56 am
Dell, it is looking really good and starting to take "shape". :thumbsup:
100* :shock: Man, That suckiths! I feel your pain :thumbdown:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby del » Fri Jul 06, 2007 11:40 pm
Peg and Mary K thank you. the heat is suppose to let up this weekend, so I should make some progress.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Jul 07, 2007 11:36 pm
I put on the other side lower skin.
I wish it had gone on like the other side! So hopefully I can fix the buckle after the glue dries, other wise run across the street, and across the churches field screaming.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Jul 08, 2007 11:41 pm
I worked on fiberglass first thing today, then had to leave the trailer alone most of the day. This evening I trimmed the tail.
del
del
5000 Club
5000 Club
Images: 410
Postby Miriam C. » Mon Jul 09, 2007 10:07 am
:applause: :thumbsup: Just amazing Del. I sure wish I could do that . I didn't hear any loud screaming so it must have worked out. ;)
Postby del » Tue Jul 10, 2007 5:37 pm
Auntie M so far so good. Then again I have not finished the fixes, more to come later. Been working on fiberglass, in places that are hard to photograph. Dragged out my heater, it is missing the outside piece that I believe keeps the rain out. I can guess what it looks like, and here is what I have.
If someone has a picture of the missing piece I would be thankful. Could I recess the whole mess and put a vented cover over it? It appears to have both an intake and exhaust in it.
del
del
5000 Club
5000 Club
Images: 410
