Thanks in advance,
Howard
Weerider wrote:The idea is to use 1/4"X4" lag bolts horizontally through trailer frame into the wall framing.
steve wolverton wrote:Weerider wrote:The idea is to use 1/4"X4" lag bolts horizontally through trailer frame into the wall framing.
Lag bolts?Why not use regular bolts? I have 5 bolts holding my camper to the trailer - I used 3/8" bolts.
Your trailer frame is wood?
Weerider wrote:I would like to have the bolts horizontal from the inside of the trailer frame into the wood perimeter frame but not all the way through so that I don't have nuts visible on the outside. I can use as many bolts as necessary.
Weerider wrote:I am ready to start building the trailer frame and am looking for suggestions as to how to attach body to frame. The section drawing is my idea for floor and wall framing. The idea is to use 1/4"X4" lag bolts horizontally through trailer frame into the wall framing. This will give me the ability to easily remove body from frame if necessary. Any thoughts or suggestions? Am I under or overbuilding the frame or body? I plan to cover the top with aluminum and the sides with wood strips.
Thanks in advance,
Howard
madjack wrote:....we use the same self tappers that Rich linked to for the same reasons...they are very stong................
