fornesto wrote:It can depend on the tow vehicle to a degree. If you make the trailer too low and are towing with a full size pick up truck, it might pull the tongue up and put the tail down. I'm not sure what you're towing with, but I'd measure the ball height and start there. Remember that the trailer will push down slightly on the ball (tongue weight), but usually not enough to make a real difference. I always shoot for level.
On a related note, you might have noticed that big travel trailers and fifth wheels ride a lot higher than they used to. This is in large part due to the tendency of new trucks, especially 4wds to sit much higer from the factory.
Alphacarina wrote:Handy chart Mike!
Our old tire calculator has been shared all over the Internet for years and years, Jack - I have 22K+ posts on MiataForum . . . . been a moderator there for 6 or 7 yearsmadjack wrote:...here is a tire height/size calculator to play with http://www.miata.net/garage/tirecalc.html
mikeschn wrote:Here is that wheelcentercalc spreadsheet if you want to plug in your own numbers...
http://www.mikenchell.com/images/wheelcentercalc.xls
Mike...Alphacarina wrote:Handy chart Mike!
asianflava wrote:Maybe there should be a "Files" section that has links to the various spreadsheets etc. that come in handy when building.
Alphacarina wrote:Our old tire calculator has been shared all over the Internet for years and years, Jack - I have 22K+ posts on MiataForum . . . . been a moderator there for 6 or 7 yearsmadjack wrote:...here is a tire height/size calculator to play with http://www.miata.net/garage/tirecalc.html
Don
