All you need is a old HD, a set of torx (or a drill press) and 10-15min of work. The magnets are the shiny curved metal pieces at the bottom of the reading "arm". There is a top one and a bottom one.
JunkMan wrote:I pulled a hard drive apart, and found the magnets, but they are attached to a steel frame. How do you remove them from the steel?
The polished discs make great emergency signal mirrors for hikers, hunters, and such too!
JunkMan wrote:[quote="Eric Adams]Usually the lower is screwed or glued (like our TDs) to the frame. Use a flathead screwdriver (could be screwed from the reverse side, I have seen that) the upper is usually held be screws.
Eric Adams wrote:
They look like they are glued, I don't see any screws. Can you just knock them off with a hammer and chisel?
Yep...try that...
