You can see that 1/2 of the fiberglass tape has been wetted out with epoxy. It turns invisible when wetted out, well almost invisible.
I moved my ladder to the other side and finished it up.
All of the tape wetted out now. After this hardens (I used a medium/fast hardener so it should only be a few hours since it's so hot outside) I'll mix the last coat of epoxy with some glass bubbles and that will be all of the epoxy work. A couple coats of latex paint and you'll never know it's where two pieces of plywood meet for the roof.
All of this epoxy, woodflour, tape, epoxy + balloons, and two coats of paint is probably overkill for this project, but I wanted it done right, and this is (in my opinion) the most important seam on the camper. This is the roof, and the flattest part on my camper.
This project turned out to be a lot easier than I thought it would. I was worried about getting that spar off, I'm really glad I hadn't attached the bottom of the spar with epoxy or I'd would have still been outside trying to get it off.
Don't let fiberglass/epoxy work scare any of you guys off from using it. It is not difficult to do - it can just be a little messy/sticky.
