arnereil wrote:All of the above...... it bends easier with the grain across the tear.
Attach on one edge, put some straps/ropes and boards to keep it from getting dinged up..... wet it, put on some pressure... go have a few beers....
Give it some time to accept the new shape without breaking... 1/8" should not be that hard.
Except, I would not use heat (dry it out, bad)...... I would shape it first, then remove and put on glue. Kind of time consuming, but the end result might be better...
SteveH wrote:A trick we use building model airplanes to warp wood either into or out of shape is to use amonia. Mix about 50% amonia with water and wet the wood with the solution, bend the wood into the position you want it, and let it dry. The wood will assume the new shape.
