del
angib wrote:A U-bolt would work well around the centre/main tongue, but I can't see it working well on the angle section of the side braces.
del wrote:Doug when you say cover the inside with resin, is cloth involved? This heat is setting off the resin very quickly, without cloth I think I can work fast enough. Now is there a hot weather alternative to fiberglass to reinforce the spars?
del
doug hodder wrote:I mix mine in a roller pan with a plastic liner...like 5 pumps of resin and 5 of catalyst...mix it up, and then roll it on. I use a shorty roller, cut a regular roller in half and use it on a trim roller handle. When it is all cured, you can strip the leftovers from the liner and reuse it. Sorry, I don't know what the differences are in the different brands of epoxy and their cure times with temps...only what I'm used to. I have applied resin in those temps here on boats and still had working time with them. The cured rollers make a great fire starter in the wood stove for the winter!!!![]()
Doug
del wrote:ps mike do I get a tee shirt now, over 10,000 views.
