Weather All -Roof Sealant
Postby Dee Bee » Sun Feb 27, 2005 11:28 am
Call for Advise and Experience from all TD Builders and Dreamers...
As I start my TD build a local homebuilder stopped by and asked what I was going to do to weather proof my TD roof. He sugested roll "WeatherALL" I used this on a shingle roof repair and underlayment. It has a self adheasive back comes in 3 ' width on rolls. It is an improvemetn on the old felt paper underlayment that has been placed under shingles for year. This new product is flexible, selfsealing around nails from the shingles, etc.
I never thought of this for TD application. I suppose a top coat could go on the outside to give a finish in white.
Comments welcome...
DEE
Grace happens...
Dee Bee
Images: 55
Postby madjack » Sun Feb 27, 2005 11:51 am
...I dunno Dee, I think the key statement is "used UNDER shingles" as opposed to being the actual roof covering. I can tell you from real world experience that the various membrane type roof coverings, even the best of them, work only so-so and require lots of maintenance...is such cases "self sealing" is more a myth than not.
If you do not want to use aluminum, I suggest wood and 'glass with a spar varnish coating...my 2cents worth
madjack 8)
Postby Arne » Sun Feb 27, 2005 11:57 am
I have sent an email to see if this product can be used on plywood..... looks good, though. do not know price.
http://www.amesresearch.com/roof%20coatings.htm#mx
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby purplepickup » Sun Feb 27, 2005 1:29 pm
arnereil wrote:I have sent an email to see if this product can be used on plywood..... looks good, though. do not know price.
That looks like some interesting stuff. I'd be real interested to hear what you find out or other's opinions too. I'm still pondering what to cover my trailer with. The sides will be around 62" high x 125" long and it's 61" wide so I'm watching all the posts about exterior coverings.
So far I'm considering Flexroof. It's Filon FRP that they use for roofs of motorhomes. I'm sure it's the same stuff that's been discussed here many times. It costs $1.29/sq ft at a place within driving distance, which is somewhat affordable to me but I'm definitely open to the options you guys keep coming up with.
George
purplepickup
Postby Guest » Sun Feb 27, 2005 1:43 pm
I think Chip used FRP on his teardrop.
I'd give him a shout.
Guest
Postby Arne » Sun Feb 27, 2005 2:26 pm
I'm a 90% kind of guy... used to be a 99% guy, then I got old(er)/
If I valued looks, I'd go with some kind of non-paint covering. But for ease of build, I went with something I can brush on.
But, I did that because some of the new liquids, like resin, are now so durable, it just made sense.... but, then, I'm not going to try and win awards, I just want to protect it from the elements.
Arne
Mr. Subject Line
Images: 96
Elastomeric coating
Postby Guy » Sun Feb 27, 2005 5:03 pm
Dee Bee, Look into Kool Seal elastomeric coating, which is used on bus conversions. It is flexible and has ceramics in it , Very high tech. In addition, it has a higher reflectivity than aluminum.
try this link and search for others. http://www.koolseal.com/catalog.asp
another great source of coating infohttp://www.nationwidecoatings.com/prod10.htm
Regards,
Guy
Guy
Images: 44
Postby Mark Mckeeman » Mon Feb 28, 2005 11:36 am
Arne,
The web site has pricing for this and other products. $17 a gallon. Any answers on application over plywood?
Mark
Mark Mckeeman
Images: 10
Postby Chip » Mon Feb 28, 2005 12:36 pm
DeeBee and Dean,, I used a commercial roofing roll material called TPO,, it works pretty good but bubbles and or wrinkles are a bear to keep from forming,, its definately waterproof but the jury is still out on wheather I really like it or not,, metal sure would have been an easire solution,, I used it because of cost,, Free,,, I sell commercial roofing,
there are advantages though,, seamless front to back, as long as its not over 10' wide,, if ya had to buy it it would run about 40 cents a sq ft.
three colors,, white, pale grey or light tan. Beverly also used a pvc on her trailer, TPO is a hybrid pvc,
its a good material but is not easy to work completely flat,,
good luck,, hope this info helped
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby davel » Mon Feb 28, 2005 2:33 pm
Has anyone looked at POR-15 products. We have been looking at this http://www.por-outlet.com/shop/product_info.php/cPath/22/products_id/171
According to their support people it will cover existing paint or bare wood.
davel
Images: 32
Postby Arne » Mon Feb 28, 2005 3:58 pm
Update:
I recevied this reply from Kool Seal:
"Dear Arne:
Unfortunately, Kool Seal products are not recommended to go over any type of wood. They should not be used as the main water proofing membrane. A substrate would need to be installed.
If we can be of further assistance please contact our Customer Service department at 888-321-5665 and select option 3.
Thank you again and have a great day!"
ANOTHER:
I received a phone call from Ames. Their product can be put on wood. The recommend applying it like fiberglass resin. Wet the surface with a coat, apply polyester cloth, then another coat on top. 5 gallons, about $150 including shipping, $50.00 for 500 sq. ft of cloth. This is the best of my recollection.... but he did say it should work well on tear drops.
Anyone interested should contact them to verify everything and get more ideas...
Arne
Mr. Subject Line
Images: 96
